  front sway bar question
front sway bar question by fierofrenzy
Started on: 06-26-2017 05:56 PM
Replies: 0 (187 views)
Last post by: fierofrenzy on 06-26-2017 05:56 PM
fierofrenzy
Report this Post06-26-2017 05:56 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
hay ya'll....question.....do you have to loosen the front suspension crossmember bolts to then remove the sway bar from an 88 formula. the two brackets that hold the bar in are tight inbetween the frame, and two tabs prevent me from sliding it down. I broke a bolt already, and don't want chance a crossmember bolt snaping if I don't have to loosen tthem
