  Replacing icm on 87 gt.
Replacing icm on 87 gt. by Macondave
Started on: 06-16-2017 02:41 PM
Replies: 3 (709 views)
Last post by: David Hambleton on 06-16-2017 10:54 PM
Macondave
Report this Post06-16-2017 02:41 PM Click Here to See the Profile for MacondaveSend a Private Message to MacondaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any how to's out there?? Need to change mine out. Anything I need to be aware of? Any help appreciated. Thanks.
Report this Post06-16-2017 02:58 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I use "heat sink compound" for electronics under it, I got it at Radio shack, not the clear stuff that comes with the ICM.
I use Ac Delco, but have also had good luck with Oreillys BWD, ICM's.
Make sure to not get the wires caught under the edge of the dist cap when reinstalling.
If you remove spark plug wires from the cap when you do it, mark them so they go back in the same spot.
How to, is really similar to this, even though this isn't a Fiero. :
[This message has been edited by 2.5 (edited 06-16-2017).]
Total ratings: 463
Report this Post06-16-2017 04:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 2.5:
I use "heat sink compound"...
Yep, using heat sink compound (and not dielectric grease) under the module is critical. Otherwise you'll soon be replacing the ICM again.
David Hambleton
Report this Post06-16-2017 10:54 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
How did you determine the ICM is defective?
If it is suspect, you might try thoroughly cleaning the spade connection lugs and also the female connector contacts from the pick-up coil to make sure that the issue isn't just a deteriorated connection.
