Originally I was going to send a few of these out free for R&D but decided the best way was for me to install them to look at the design, wire routing etc. I installed one several days ago in an 84 Indy and it worked really well but I changed the design.
Looking for someone with an 84-86 Fiero who has problems with their headlights going up and/or down. I have this new device that replaces all 3 relays including the isolation relay. I installed one in an 84 Indy a few weeks ago and it works excellent. Best if you have new gears in your motors. If your bumpers in your headlight motors are original and old they will be mostly gone. If you still have the original GM plastic gears in your headlight motors I would expect those old OEM GM plastic gears to fail very quickly once this device is installed because your headlight motors will spin like new. I made a design change so this unit mounts where the isolation relay originally mounted. A much better design. So I want to install a second kit in a 84-86 to determine wire lengths, take pictures etc. Contact me: rodney@rodneydickman.com
We can still do it if you have old OEM plastic gears but expect your gears to fail quickly after. We do have to cut the factory wiring harness up some in the front area but once installed you can not really see that has been done. We use the original wires going to the passenger side headlight motor so the installed look is close to OEM.
If anyone close by is willing to stop in here I would put this in your 84-86 N/C. Take pictures etc.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
