  Kudos to Rodney Dickman again!!!!
Kudos to Rodney Dickman again!!!! by Curtisk1060
Started on: 03-14-2017 08:49 PM
Replies: 4 (499 views)
Last post by: Fiero Vampire on 03-17-2017 06:26 PM
Curtisk1060
Report this Post03-14-2017 08:49 PM Click Here to See the Profile for Curtisk1060Send a Private Message to Curtisk1060Edit/Delete MessageReply w/QuoteDirect Link to This Post
Had to share that once again Rodney came through for me in finding a shaft seal for my sons 87GT rack and pinion which I was rebuilding. I had already ordered the bushing and outer tie rods from Rodney but could not locate a shaft seal. Rodney was able to find one and included it with my parts to have me verify its fit. Well as usual his parts, all of them, were a perfect fit, the instructions were clear and fairly easy to follow. For not much money the 87GT rack and pinion is now better than original. The seal provided I believe is better than factory as it has a small inner circumference spring like you would expect on most shaft seals that the factory one does not have. It turned out I could have re-used the original shaft seal but the one Rodney provided was better in my opinion. Thanks again Rodney, you cannot beat him as a Fiero parts supplier for good well thought out parts that work better then original!!! Curtisk1060
lorennerol
Report this Post03-15-2017 10:55 AM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Truth. Everything I've ever seen or gotten from him has been superior quality. It's a good feeling to put a part on the car and know it will last and perform.
Kevin87FieroGT
Report this Post03-15-2017 10:47 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another nice RD part is the "Big Brake Booster Installation Kit". The adapter fits and functions perfectly as many of his other products. It's also nice to purchase the booster itself from Summit with a good price, free shipping, warranty, no core charge, powder coated exterior, and all new parts. Easy to follow instructions as well.
Good work Rodney!
[This message has been edited by Kevin87FieroGT (edited 03-16-2017).]
Rexgirl
Report this Post03-17-2017 03:30 PM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney's parts are first rate, as are his ethics. A terrific vendor !
Fiero Vampire
Report this Post03-17-2017 06:26 PM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can personally recommend, his balljoint separator tool, dew strip removal tool, shift cables, headlight gears, master & slave clutch cylinder, 2.8 idler pulley, adjustable solid dog bone, V-6 Alternator reinforcement plate, door hinge kit, and 1988 Inner & outer Tie Rods, 1988 Rubber Radiator Hoses. quality has been amazing, to the point that I wouldn't hesitate to buy any thing he sales that I need to need.
