  scanner for 3800 or uvscan on x64 PC
scanner for 3800 or uvscan on x64 PC by tampalinc
Started on: 02-14-2017 09:39 PM
Replies: 3 (176 views)
Last post by: nosrac on 02-16-2017 05:02 PM
tampalinc
Report this Post02-14-2017 09:39 PM Click Here to See the Profile for tampalincSend a Private Message to tampalincEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone been able to get uvscan to work on a Windows 7 x64 PC, or is there another free scanner people are using?
I dusted off the DHP Powrtuner and got it working. I just haven't been able to get uvscan to work.
Buck531
Report this Post02-14-2017 10:46 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
The DHP software works fine for me.
Report this Post02-16-2017 03:28 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try run as admin.
Try run as XP or vista etc
both are on properties, compatibly tab.
If problem program has drivers to use... x64 OS needs Signed x64 Drivers or won't work.
Win7 pro and up can get "XP mode" is a XP VM in Win7.
Among other issues, this allow you to install Signed and Unsigned x86 (32bit) drivers in the XP window.
nosrac
Total ratings: 50
Report this Post02-16-2017 05:02 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
Try run as admin.
This
First u have to install the MTSSDK.ocx file. There is an install.bat file that you have to edit and run.
After you edit this line regsvr32 C:\temp\UVSCAN\MTSSDK.OCX to point to correct file location then Right click and run as admin.
