  Removing non AC temp control slider knobs
Removing non AC temp control slider knobs by jjd2296
Started on: 12-08-2016 08:35 PM
Replies: 4 (285 views)
Last post by: jjd2296 on 12-10-2016 11:20 AM
jjd2296
Report this Post12-08-2016 08:35 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
I found some temp control slider knobs in Chrome so o picked them up. I tried to remove the 2 existing knobs but they just wouldn't come off! Is that normal? Is there a trick to removing them? Did the previous owner happen to lock tight them on? I'm confused!!
jjd2296
Report this Post12-09-2016 03:56 PM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
someone must have tried to remove these before??????
Shho13
Report this Post12-09-2016 04:00 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
The slider that goes from 'hot' to 'cold'?
They just pull off with a bit of force. Use a flat head screw driver and pry it off, stick a paper towel or something under the screwdriver to prevent damaging the face.
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
jjd2296
Report this Post12-10-2016 11:19 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
i tried prying them off with plyers with no luck! I fear the previous owner glued them on!
jjd2296
Report this Post12-10-2016 11:20 AM Click Here to See the Profile for jjd2296Send a Private Message to jjd2296Edit/Delete MessageReply w/QuoteDirect Link to This Post
jjd2296
Member since Jan 2016
oh nd to be clear I'm talking about a non AC model with 2 sliders one for heat other for vent
