  Pics and info needed for a Fiero I purchased last week
Pics and info needed for a Fiero I purchased last week by JetroGT
Started on: 12-07-2016 08:23 AM
Replies: 14 (599 views)
Last post by: JetroGT on 12-10-2016 11:56 AM
JetroGT
Report this Post12-07-2016 08:23 AM Click Here to See the Profile for JetroGTSend a Private Message to JetroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The original owner used to be on this Forum.
https://www.fiero.nl/forum/A...050410-1-046790.html
He sold his car in 08 and the next owner just drove it, and it now has issues that I need to address.
I'm looking for more detailed engine pictures. There is some stuff that is disconnected or not working. Like the cruise control and overdrive. The engine needs plugs and wires among other things. If you have any pics archived please post them.
Here is the car the day I bought it.
When I get a chance I'll post more pictures.
Thanks.
JetroGT
Report this Post12-07-2016 08:13 PM Click Here to See the Profile for JetroGTSend a Private Message to JetroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The info was a long shot.
I took some pics of the engine compartment and reviewed them on the computer. It looks like some mice or rats have chewed up the wiring. I guess that's why the car was only $2500.00. I drove it for two days and clocked about 250 miles. The cars driveability progressively got worse to the point the beater car was preferable. Here's what I found.
This is probably why the trans shifts late and has no OD.
Why it runs so crappy.
Probably going to reroute the throttle cable to where it should be and reconnect the cruise control. I love cruise control.
Total ratings: 463
Report this Post12-07-2016 08:54 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remember that car, now.
I have a 4.9 with the Allante setup. I retained the throttle cable that the Fiero Factory installed with the original 4.9 installation. Basically an 88 Duke throttle cable.
I fabbed up a clip/clamp affair to attach to the throttle lever. It sort of looks like a V6 throttle cable might have actually worked better, assuming it would reach. But I just worked with what I had. Six years later it still works fine.
Grantman
Report this Post12-07-2016 08:59 PM Click Here to See the Profile for GrantmanSend a Private Message to GrantmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess this is why I didn't get a response from the CL ad. car is sold but the owner didn't take the ad down. Great color!
http://kansascity.craigslis.../cto/5890456765.html
1986 Fiero GT fastback SC3800 3.4 pulley, FSIC, N*, 1.9 rollers
1998 Jeep Grand Cherokee with 5.9 motor
1985 Honda V65 Magna
[This message has been edited by Grantman (edited 12-07-2016).]
JetroGT
Report this Post12-08-2016 06:03 AM Click Here to See the Profile for JetroGTSend a Private Message to JetroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Raydar. When you perform a tune up on your engine do you remove the Allante intake? I'm probably going to just to make the job easier. When I still had the 87 with the 4.9 I could get to the plugs from underneath the car. This car has true dual exhaust. I'm hoping that I can get to the firewall plugs from the bottom. I bought the iridium AC Delco plugs and MSD wires. The goal is to get the issues resolved on Friday while the kid is in school. We'll see.
Report this Post12-08-2016 09:39 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fat plug 3 wires looks like OP sender plug...
Upgrade to 88 plug and sender. If they fail, won't leak pressurize oil out of engine.
See my Cave, Oil Sensor
JetroGT
Report this Post12-09-2016 10:04 AM Click Here to See the Profile for JetroGTSend a Private Message to JetroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I'll put that one on the list. I have had a OP sensor leak like that before.
Working in the cold today. I picked up my MSD wires. It turns out they ordered the wrong set. They have 90 degree ends instead of the straight ends. So I'll go back and get a credit. I'll probably go with what they have in stock and revisit the wires in the spring. I found the miss fire. It's cyl 1 injector cable. Something chewed through it. I'm going to pull the plug to see how bad they are. If they look good I'll roll them into the spring tune up.
JetroGT
Report this Post12-09-2016 10:55 AM Click Here to See the Profile for JetroGTSend a Private Message to JetroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
JetroGT
Member since Jul 99
Started on the firewall side. I'm surprised that this car even ran. Here is the cyl 4 wire.
I went back out and started pulling the plugs. I've got all but #6. The car has true dual exhaust and the cat is right in the way. So I'm trying to get it from the top. I found some good stuff under the car. Aluminum cradle bushings and poly control bushings.
[This message has been edited by JetroGT (edited 12-09-2016).]
JetroGT
Report this Post12-09-2016 12:18 PM Click Here to See the Profile for JetroGTSend a Private Message to JetroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
JetroGT
Member since Jul 99
Got it. I don't think the old platinum's were at end of life but I wanted to start fresh. Double platinum plugs
Total ratings: 463
Report this Post12-09-2016 06:28 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've only had the plugs out once, since I did the Allante setup, but yeah... it has to come off. Unless you're a lot more limber (and thinner) than I am.
Not really a big deal, though. Throttle cable; 3-4 vacuum lines (All the ports are NOT the same. Mark them with tape tags or something); Three or 4 sensors;
Four 13mm nuts hold the whole thing on. You can leave the throttle body attached, or remove it. Whatever is more convenient for you.
With that said, I had very little trouble getting the plugs out from the top. Not really any more difficult than the V6.
(I absolutely *hate* lying on the ground under the car.)
Mine also has the 88 oil pressure switch. I've had several of them short out and kill the battery, due to the pump running all the time.
I ended up changing the wiring on the fuel pump circuit to "switched". That will horrify some people, but it's worked fine for me, for several years.
[This message has been edited by Raydar (edited 12-09-2016).]
JetroGT
Report this Post12-09-2016 06:50 PM Click Here to See the Profile for JetroGTSend a Private Message to JetroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
A switch on the fuel pump circuit is a good idea, and a nice anti-theft feature. On a side note I finished replacing the plugs wires and removed this blockage from the intake. lol
From a stop it's like a rocket, but the transmission is still an issue. It's shifting into all the gears, but it's just shifting very late. 1st gear 5K. If I floor it, it goes past the red line. At 70 it tachs at 3.5k with no Over Drive. I'm used to the DeVille 4spd where at 80 the tach is sitting at 2K and I'm getting 30+mpg. I still have to ask Jeremy how much it is to swap out a transmission.
Total ratings: 463
Report this Post12-09-2016 07:27 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Contrary to popular belief, the Fiero Factory (if they did the swap) do NOT change the tach calibration. At least they didn't with mine.
At WOT, it will shift at ~6K as indicated by the V6 tach, In reality, it's closer to 4500.
If you are not confident, get a scan tool and plug in. It will tell you the correct RPM.
(You probably are idling at 1000-1100 indicated. Probably closer to 700-800. )
The stock ECM has a rev limiter, so even if it's NOT shifting until late, it should shut off the injectors before anything breaks.
JetroGT
Report this Post12-10-2016 08:30 AM Click Here to See the Profile for JetroGTSend a Private Message to JetroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The temp gauge is pegged / upside down. I think I remember reading that if the operating temp does not reach a certain point, the engine will not go into closed loop and will not engage lock up. I need to find the temp sensor to measure it's resistance and measure the resistance of the plug.
Total ratings: 463
Report this Post12-10-2016 10:30 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Temp sensor should be in the intake manifold, right next to the thermostat housing. There is also a heater hose outlet, right there at it.
With that said... There is normally only a provision for one sensor on the Allante manifold.
I tried the 3 wire sensor - the one that had the circuits for both the ECM and the gauge. I never could get the gauge to read correctly. It would go from "cold" to "pegged", in about five minutes. I figured that either the resistance was wrong, or there was a ground loop somewhere. In any event, it just wasn't worth the trouble to sort it out.
I ended up adding a "T" in the heater hose, just outside of the heater hose outlet, and running the stock Fiero gauge sender.
The one in the manifold is the regular 2 wire sensor for ECM.
I can take pics of anything you want, if you need them.
I would suggest borrowing a scanner and seeing what the ECM thinks it's seeing. It will provide a wealth of information.
ALDL does not support the Caddy ECM. You'll likely need a real scanner.
FWIW... I also drilled a pin hole in my thermostat, to prevent air from getting trapped. (If yours is not warming up, it may have had the thermostat removed.)
[This message has been edited by Raydar (edited 12-10-2016).]
JetroGT
Report this Post12-10-2016 11:56 AM Click Here to See the Profile for JetroGTSend a Private Message to JetroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm going to have to make a full inspection of all the critical engine management parts. I'm hoping I can make the Dells this year. This year will make 7 years that I've missed it.
