  Low profile ,portable ramps..
Low profile ,portable ramps.. by fireboss
Started on: 11-28-2016 02:21 AM
Replies: 5 (419 views)
Last post by: Falcon Fiero on 11-29-2016 01:00 AM
fireboss
Total ratings: 58
Report this Post11-28-2016 02:21 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
A few months back I purchased 2 sets of Aluminum low profile car ramps.
Ramps
They came 2 in a set and have a storage bag with them.
----They are NOT for getting under the car to work on at all-----
They are perfect size for anyone who has lowered there car to the point where even the low profile jacks are hard to get under.Mine was lowered before I bought it.
I have an 88 that is a pain to get under..They are all Aluminum and they store perfectly in the trunk.
I added some grip tape on the top of mine.And some 1/4 inch strips of rubber along the bottom.
Just thought I would pass along a pretty good solution to cars that are lowered low..
tesmith66
Total ratings: 135
Report this Post11-28-2016 06:18 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Made a set out of wood when I got my first Fiero 21 years ago. Since then I got a low profile hydraulic jack.
I bet those are lighter than my wood ones, though.
1986 SE Aero coupe.
Fiero 88
Report this Post11-28-2016 07:12 AM Click Here to See the Profile for Fiero 88Send a Private Message to Fiero 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Since I'm cheap, this is my method as well. Doesn't look quite as nice as the aluminum ones though.
Past:
1988 base coupe sold
1984 base coupe rust
Present:
1986 SE 2m6
hyperv6
Total ratings: 93
Report this Post11-28-2016 05:12 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
I bought the set up low ramps from Race Ramps. They are made of a light composite and really do the job well. They are easy to store and light enough you can easily hang up anywhere.
Not cheap but I got them at cost so it made it a good option for me.
I also had a set of plastic street rod ramps. they were also great and very cheap. They worked great till I got brake fluid on them and they started to fall apart. I can not remember the brand name.
Report this Post11-28-2016 08:01 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
A few months back I replaced my old normal height larin jack to a harbor freight low profile one. It is very low and a nice long reach (#68050, 62310, 60678)
http://www.harborfreight.co...apid-pump-68050.html
Time will tell how durable this jack is, but I really like the low profile (about 1 1/4" lower than the Larin) and nose length!
The jack pad is right under the front lower frame rail:
Falcon Fiero
Report this Post11-29-2016 01:00 AM Click Here to See the Profile for Falcon FieroSend a Private Message to Falcon FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently got some "Race Ramps" to replace the old Rhino ramps I bought for my lowered 88GT.
The Race ramps have a much longer approach angle so the front end does not scratch.
Additionally, you can remove part of the ramp after loading ( see attached photo), which makes it much easier to work under the car.
I highly recommend them.
[This message has been edited by Falcon Fiero (edited 11-29-2016).]
