  Water leak
Water leak by 85fieroguy
Started on: 10-01-2016 09:51 PM
Replies: 3 (134 views)
Last post by: jaskispyder on 10-02-2016 11:53 AM
85fieroguy
Report this Post10-01-2016 09:51 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tried to find a small water/coolant leak in right rear of car. Checked the " weep hole" of water pump, hoses etc. Is there a dye I can put into the overflow and check with a " glow light" like when they put dye in the oil to test for leaks . Someone suggested food coloring, but I think it would get diluted to much to detect the source. Any ideas guys ???
Report this Post10-01-2016 10:42 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Shho13
Report this Post10-02-2016 01:21 AM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can be the thermostat housing, weep hole, or even the hose on the right side coming off the coolant pipes... It's usually the highest point you see moisture present.
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
jaskispyder
Total ratings: 205
Report this Post10-02-2016 11:53 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another item to used is a coolant system pressure tester. It will allow you to pressurize the system and look for leak. Helped me find a bad headgasket. You can borrow one from auto parts stores.
