  Car Fix- Fiero motor swap on TV
Car Fix- Fiero motor swap on TV by LitebulbwithaFiero
Started on: 10-01-2016 09:18 AM
Replies: 25 (1859 views)
Last post by: E.Furgal on 10-06-2016 01:26 PM
LitebulbwithaFiero
Report this Post10-01-2016 09:18 AM Click Here to See the Profile for LitebulbwithaFieroSend a Private Message to LitebulbwithaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just saw on that they are doing a N* swap in a Fiero on the show. On at 11 this morning on Velocity channel
[This message has been edited by LitebulbwithaFiero (edited 10-01-2016).]
Report this Post10-01-2016 10:39 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the heads up!
I set it to record. It is only a 30 minute show so I am curious as to what they choose to discuss.
Oregon88
Report this Post10-01-2016 11:02 AM Click Here to See the Profile for Oregon88Send a Private Message to Oregon88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sweet!
I'm watching now,
First thing I hear,
"It's a sports car, I guess" lol
Shho13
Report this Post10-01-2016 11:18 AM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ooo... Watching now! Thanks!
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
LitebulbwithaFiero
Report this Post10-01-2016 11:27 AM Click Here to See the Profile for LitebulbwithaFieroSend a Private Message to LitebulbwithaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for the lie, guys
Shho13
Report this Post10-01-2016 11:32 AM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bummer, It's over. Showed how to fix the common problems with an 02 Northstar engine. Anyone know when the next episode will be?
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
Jonathan Tate
Report this Post10-01-2016 11:54 AM Click Here to See the Profile for Jonathan TateSend a Private Message to Jonathan TateEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car Fix Season 5 Episode 11
Car Fix
NorthStar Transplant
EPISODE INFO
What does a Pontaic Fierro need? A Cadillac Northstar engine is correct. Jared and Lou show you how to fix the common oil sealing problem in NorthStar engines before it finds its new home. 30 Min. | PG
Total ratings: 205
Report this Post10-01-2016 01:28 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good info on the N* engine.
I hope they do a show on the install into the Fiero.
I'm curious how they will approach drive line control.
[This message has been edited by olejoedad (edited 10-01-2016).]
Total ratings: 328
Report this Post10-02-2016 08:17 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe that the greatest challenge to swapping the N* engine into a Fiero is the powertrain management issue with the 4T80e transmission. The swap has been done before but I believe with a stick and an aftermarket ECM. It will be a most interesting program when they do the Fiero swap. Obviously all the TV episodes are pre-recorded so the swap has most likely been finished and on the road.
The N* engine is a nice powerplant but with its history of gasket failures , I don't know if it makes the ideal choice. The 300HP is nice to have but other V6 GM high feature engines can give it as well.
E.Furgal
Total ratings: 278
Report this Post10-03-2016 05:35 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Guess you didn't watch the show..
The gasket failure is covered, and they show the fix... it is a known issue that is simple to fix for ever..
The trans control.. and for that matter the engine control,, might be better off leaving the G.m. system in the parts pyle..
They also hinted at the reason for the N* it is cheap.. one thing the high feature g.m. v6's are not.. and not fer nothing, the v8 rumble is something you can't get in a v6..
The aftermarket that feeds the caddy 426/472/500 crowd is moving into this power plant.. so if history is a guide the future is bright for the N* as a cheap all alum high strung v8 .. something even the ls can't claim.. as the all alum ones are far from cheap..
Report this Post10-04-2016 12:11 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Somebody youtube it pleeeeease?
[This message has been edited by 2.5 (edited 10-04-2016).]
E.Furgal
Total ratings: 278
Report this Post10-04-2016 05:47 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
It'll be rerun a billion times on velocity
dobey
Total ratings: 371
Report this Post10-04-2016 07:26 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bit of an odd statement really. The N* is cheap because nobody wants them. The LS is more expensive because everyone wants them (but they can be had cheap). The N* is also still quite heavy, despite being aluminum, as it's DOHC. How much do you think it would cost to get the same performance and reliability out of a N*, that one gets from even the cheap LSx engines? Heck, even the iron truck engines will be about the same weight as a N*, if not lighter, and an make way more power. Granted, the cost to drop one in a Fiero is by no means cheap, but I don't see any aftermarket being built around the N*, just the same as there isn't really any around the Caddy High Technology (4.1/4.5/4.9) V8s.
Report this Post10-04-2016 07:42 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the show, their definition of cheap for their junk yard N* was $1000 to $1500. The show didn't comment if that was just for the engine, or the complete drop out with engine, transmission, harness, and all accessories. LS4 is the bastard step-child of the LS family, but they are all 5.3L, all aluminum, and nearly all the LS go fast parts work on it too.
I have purchased 3 LS4 complete drop outs with everything ranging from 18K miles to 100+K miles and haven't paid more than $1000 for any of them.
Mine has 382 whp at a lofty 6800 rpm and nearly 80% of the 335 rwtq peak is available from 2000 to 7000 rpm. Cheap, high strung, aluminum v8 it is!
[This message has been edited by fieroguru (edited 10-04-2016).]
Report this Post10-05-2016 08:28 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Doesn't help me I don't have cable.
E.Furgal
Total ratings: 278
Report this Post10-05-2016 09:16 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
find me any under 100k 6.0 or 6.2 all alum ls for under 2500.00 that is not warm to hot..
E.Furgal
Total ratings: 278
Report this Post10-05-2016 10:01 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
E.Furgal
Member since Mar 2012
I wish I didn't the bill is crazy,, but the wife claims she has to have this and that channel..
Report this Post10-05-2016 10:04 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hard to be frugal and married
dobey
Total ratings: 371
Report this Post10-05-2016 10:32 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I paid $1200 total including shipping for my LS4 with only 10K miles.
I could certainly find an LS1, LS6, or LS2 for under $2500 easy enough if I cared to do so. The LS6 and LS2 are already starting a full 100+ HP more than the N* too. You'd be hard pressed to find a newer N* that already has all the head bolt and oil issues fixed with less than 100K for anywhere near that price too. And the LSx will still be cheaper to mod, and will be lighter.
Total ratings: 328
Report this Post10-05-2016 11:37 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did watch the show and the head gasket fix is not that easy. It requires a major tear down. The big point is to use an engine that doesn't have a history of gasket problems so you won't have to tear things down to fix them. The swap is enough work. Do we need more work?
E.Furgal
Total ratings: 278
Report this Post10-06-2016 08:49 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been looking for a few years.. for a 6.2 for my SS.. never are they under 3k and that is if they split the engine/trans..
The yard that has one low miles 25k 6.2 6 spd 5500.oo 6k if you want the harness and ecu etc.
Report this Post10-06-2016 09:20 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Probly regional prices, but I don't know where Dobey is located.
dobey
Total ratings: 371
Report this Post10-06-2016 09:45 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't limit my searching to local yards.
But the point was that "aluminum" is irrelevant for the most part in the front engine rwd cars, unless one is really trying to build an ultralight race car, especially when comparing to a Northstar. The iron LSx truck motors are mind numbingly cheap to get, and are lighter than the Northstar, and already make more power from the start.
dobey
Total ratings: 371
Report this Post10-06-2016 09:51 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
So because you can't find an LS3 for under $3K, the Northstar is somehow a better option? If it's so important to have a 6.2, how would getting a 4.6l DOHC solve that problem? How much do you think it would cost to turn the Northstar into a 6.2l engine? More than $3K I bet.
And if 4.6l is acceptable, get a 4.8l truck motor. They are super cheap, weigh less than the Northstar, and can easily make much more power and rev to 7000 RPM. Yes, aluminum engines are more expensive. But my point was that the aftermarket crowd is not going to move to the Northstar. Maybe you think an all aluminum V8 is important, but everyone else in the world swapping modern engines into old cars is already doing truck motors because they are cheap and easily make lots of power. There's no reason to expect there will somehow be a bigger aftermarket for the Northstar in the future; especially as the world moves further away from fossil fuels.
dobey
Total ratings: 371
Report this Post10-06-2016 10:08 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Well, I don't know about you, but I'd rather find and fix problems before putting an engine in, rather than having blind faith on the condition of it. Better to do it now, and know things are good, than to wait until things break going down the road. Besides, it's a good time to do all the performance mods/upgrades before you put the engine in, rather than taking it back out and doing that rebuild later on.
E.Furgal
Total ratings: 278
Report this Post10-06-2016 01:26 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
no, the ls is for my 86 SS my Fiero is an INDY I'd like to put an baby N* in it.. or an N* or a superduty.. Last thing I want in this one is a belly button LS..
We'll see. Ithought the n* lower end is overbuilt.. so you can make up the lack of head flow with shoving the air down it's throat
