  Lights on dash
Lights on dash by 85fieroguy
Started on: 07-26-2016 11:07 PM
Replies: 2 (181 views)
Last post by: no2pencil on 07-27-2016 07:28 AM
85fieroguy
Report this Post07-26-2016 11:07 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't seem to shut off the hand brake light..any ideas?? also. My door a jar light seems to "flicker" on and off at will. Adjusted the door bolt to get rid of rattling but the light never flickered before. Ideas ???
1986 Fiero GT
Total ratings: 54
Report this Post07-27-2016 12:59 AM Click Here to See the Profile for 1986 Fiero GTSend a Private Message to 1986 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are door pins in each door jamb [near the top hinge, I think] that will break connection to chassis ground when the door has been closed. I'd check them to make sure the 1/4" female disconnects are secure and they're not rusty garbage. They're run in parallel, so they're effectively on the same wire. I'd start there.
Same with the parking brake. There is a switch integrated into the assembly that goes to chassis ground when the lever is pulled. It's a mechanical switch [remember, these cars are 30+ years old] and also could be filthy, rusty or faulty. Again, check the connector at the switch as well. If everything checks out there, trace the wiring back to its source. A pinched wire or short to ground through missing or damaged insulation could cause these issues.
Good luck.
no2pencil
Report this Post07-27-2016 07:28 AM Click Here to See the Profile for no2pencilSend a Private Message to no2pencilEdit/Delete MessageReply w/QuoteDirect Link to This Post
For a while I had a flickering ajar light. The decklid was barely pressing down on the push-button indicator. It was fixed by adjusting.
