  Stock "Hi-Tech" Alloy Rims - Other Options to Accommodate Wider Tires?
Stock "Hi-Tech" Alloy Rims - Other Options to Accommodate Wider Tires? by Cokeologist
Started on: 07-19-2016 10:16 AM
Replies: 12 (677 views)
Last post by: Carcenomy on 07-23-2016 07:41 AM
Cokeologist
Report this Post07-19-2016 10:16 AM Click Here to See the Profile for CokeologistSend a Private Message to CokeologistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for some guidance regarding rim options. The goal is to retain the look of the stock “hi-tech” alloy rims while allowing for a wider tire on the rear.
I have an 85 Fiero 2M6 and prefer the look of the stock “hi-tech” alloy rims with RWL tires (currently have Goodrich Radial T/A RWL P215 60R 14 all the way around; pic from before new tires):
I would like to move to a wider tire on the rears, but the only option I can find for the Goodrich Radial T/A RWL that will fit the stock 14” x 6” hi-tech alloy rim is a P225 60R 14. This is only 10mm wider than my current tires, which doesn’t seem enough to justify changing (235’s require a 6.5”w rim, and 245’s require a 7”w rim per Goodrich specs).
Are there any other rim options, perhaps from other Pontiacs of the era, that retain the same look of these hi-tech alloy rims and that will direct bolt on to the stock wheel bolts, and also provide appropriate rear wheel well clearance? If there are such rims but not direct bolt on, is there an adapter that would work? I would prefer to change only the rear rims to accommodate the wider tires, and retain the current BFG P215 60R 14s in the front. Thanks in advance for the guidance.
TXOPIE
Report this Post07-19-2016 10:36 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a company in the UK that utilizes "Hi-Tech" fiero rims and makes them into a larger sized rim...need to hunt for their site...there was a thread somewhere on the forum a few years ago about them.
Here is a picture of them.
Found the link:
https://www.fiero.nl/forum/Forum1/HTML/091851.html
[This message has been edited by TXOPIE (edited 07-19-2016).]
viperine
Report this Post07-19-2016 04:02 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would just switch tire brands. I love my fat, white letter Mastercraft avenger g/t's.
The firebird got wheels like this for the third generation (82-92) but only certain ones got this convex facing, and the bolt pattern is 4.75". No clue what difference there is in offset. Wheel adapters are strongly discouraged.
Report this Post07-19-2016 05:27 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Firebird wheels are probably wider, but you'd have to switch bolt patterns.
[This message has been edited by 2.5 (edited 07-20-2016).]
Report this Post07-19-2016 07:45 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If there is clearance on the back side, you could look into getting them widened on the back side. I think the cost is around $150 per wheel and here is just one of likely several vendors http://www.ericvaughnmachine.com/Services.html
Here is a sample pic from google:
[This message has been edited by fieroguru (edited 07-19-2016).]
David Hambleton
Report this Post07-19-2016 10:18 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a new '84 SE in May of '84. I put 235/60 all around the first time it needed tires. They fit and worked fine, but I've been using 225/60 since. (32+ years, 372,000 kilometers and still going.)
trivet
Report this Post07-20-2016 08:00 AM Click Here to See the Profile for trivetSend a Private Message to trivetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Cokeologist:
I'm normally not a fan of this style of wheel, but THOSE are the nicest I've EVER seen. Beautiful!
Cokeologist
Report this Post07-20-2016 08:07 AM Click Here to See the Profile for CokeologistSend a Private Message to CokeologistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks; my resto shop did an unbelievable job with my restoration all around, including the wheels. As you can see, they added an Indy wheel tape stripe which was a really nice touch.
Cokeologist
Report this Post07-20-2016 08:08 AM Click Here to See the Profile for CokeologistSend a Private Message to CokeologistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cokeologist
Member since Nov 2010
Thanks 2.5; pls pardon my ignorance but what is involved in switching bolt patterns?
Report this Post07-20-2016 08:46 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not fully up to speed on that myself actually. It would involve either a hub swap, or using adapters, both of those open up their own cans of worms. I hope someone who has done it will comment.
The offset becomes important so the wheel doesn't stick out of your wheel well, it might be that adding to the back of the wheel itself is the best option.
Cokeologist
Report this Post07-22-2016 08:11 AM Click Here to See the Profile for CokeologistSend a Private Message to CokeologistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a bump in hopes that someone can enlighten me on this. Thanks.
TommyRocker
Report this Post07-22-2016 11:56 AM Click Here to See the Profile for TommyRockerSend a Private Message to TommyRockerEdit/Delete MessageReply w/QuoteDirect Link to This Post
You'd be better off having your wheels widened, especially if you only want the rears done. The only way to switch wheel patterns without having to mess with hubs and brake rotors is to use spacer/adapters, and between the adapter and the (wider? Offset?) Firebird wheel you'd be sticking the wheels out past the fender.
Carcenomy
Report this Post07-23-2016 07:41 AM Click Here to See the Profile for CarcenomyClick Here to visit Carcenomy's HomePageSend a Private Message to CarcenomyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found the link:
Essentially these UK guys just broke out the big lathe and parting tool, cut the Hi-Techs down to centres and bolted on wider and larger diameter barrels. I'd call a wheel builder like HRE or Rotiform and run it by them, they'd likely be able to do something to this effect
[This message has been edited by Carcenomy (edited 07-23-2016).]
