  replacing rear 1/4 panels
replacing rear 1/4 panels by fierofrenzy
Started on: 06-28-2016 07:25 PM
Replies: 3 (155 views)
Last post by: Australian on 06-29-2016 04:36 AM
fierofrenzy
Report this Post06-28-2016 07:25 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi ! I'm looking forward here to advise / instructions on removing and replacing the rear 1/4 panel body sections. Actually, I got a set of side scoop panels that I'll be installing in replacement. This will be on an 88 Formula. At first glance, I see what appears to be plastic rivets holding the panel(s) on. so I'm assuming to simply sheer off the head of the rivets and the panel comes off. I see Fiero Store has the replacement rivet kit. Appears to be relatively simple. Am I right? Do I need any special tools ?
One things for sure. These functional side scoops are super cool ...no pun intended....and I'm eager to get them on.
Total ratings: 463
Report this Post06-28-2016 08:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you can't simply punch the center of the rivet out first.
viperine
Report this Post06-28-2016 09:28 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I seem to recall a bag of F-bombs being the primary tool needed to get those plastic rivets out. I think a cordless drill with the right drill bit would be easier even though it's not metal. A set of plastic trim panel spatulas/putty knives will be nice to have on hand. I will be doing this very task on one of my cars in a week, so good luck!
Australian
Report this Post06-29-2016 04:36 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are a couple of metal rivots as well to drill out just be sure to buy new trim holders before you start as your going to destroy those as brittle.
