  Lt1 Ac compressor
Lt1 Ac compressor by Easy8
Started on: 06-21-2016 06:20 PM
Replies: 1 (128 views)
Last post by: Raydar on 06-21-2016 07:50 PM
Easy8
Report this Post06-21-2016 06:20 PM Click Here to See the Profile for Easy8Send a Private Message to Easy8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Quick question for all you guys/gals that run an Lt1 with A/C. Which compressor do you run with this swap. I have a fiero compressor but of course the pulley is wrong. Would I do better buying a new clutch assembly or just get a compressor for an LT1? Thanks
Total ratings: 463
Report this Post06-21-2016 07:50 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The compressor for a 4.9 is nearly identical to the Fiero compressor, except that it has the pulley for the serpentine belt.
A replacement compressor that I purchased had plugs in the rear head for the pressure switches. The original 4.9 compressor had no provisions for switches.
