  Harmonic Balancer Milling/ DIS
Harmonic Balancer Milling/ DIS by Smooth
Started on: 06-05-2016 12:19 AM
Replies: 1 (147 views)
Last post by: Spoon on 06-06-2016 08:25 PM
Smooth
Report this Post06-05-2016 12:19 AM Click Here to See the Profile for SmoothSend a Private Message to SmoothEdit/Delete MessageReply w/QuoteDirect Link to This Post
Greetings-my first post, IIRC....
I believe there was a fellow offering milling services to make a harmonic balancer have the 7 slots needed for a CPS.
Anyone have the contact information?
Also, does anyone manufacture the mounting bracket for a Crankshaft Position Sensor as featured in the blueprint?
I really would like to get all the necessary parts/milling for a DIS/ 7730 conversion.
Thanks,
kerry
AG4YW
Spoon
Total ratings: 61
Report this Post06-06-2016 08:25 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I planned on going this route for my 86 2.8 some time ago and dropped the ball. I've got everything needed for the conversion.
ECM FROM 1989 CORSICA 07/89 WITH 52K MILES. ECM STAMPED REMANUF. # 16198262 / REPLACEMENT FOR 1227730.
ECM 1227730 w / V6 Mem-Cal , (3) Connectors w / pigtails
Knock Sensor / Matches Mem-Cal / Same vehicle
ECM Tray to fit the 1227730
Coil Pack with Ignition Module
Crank Sensor / New
Custom bracket/ for mounting crank sensor. Replaces original timing bracket.
Dummy Plug w/ gear & shaft to replace distributor
Digital EGR Valve
EGR Adapter Kit / New still in package
2.8 Harmonic Balancer / Needs slots machined
Freeze Plug to block 7th injector port
I'll recheck to see if I missed anything. Keep an eye out in the mall. I'll try to post this within a few days.
Spoon
