I know there are sill plates out there for the Fiero but I wanted something a little less flashy than mirror, so I came up with this textured ABS plastic one. Monday when I get my pantograph I will play around with carving Fiero GT on it with some flutes that run parallel that I can lay some paint in the letters and flutes which match the color of the car.
I like those!! Question though, for those of us that have cracked rocker sills, could it be extended a little to cover the cracks? And the matching lettering would be awesome!!
....................I will play around with carving Fiero GT on it with some flutes that run parallel that I can lay some paint in the letters and flutes which match the color of the car.
If the actual door sill is in good enough condition, you could have your machine completely remove the areas for the flutes and logo and let the original sill color show through. It would save you some headache because paint has a hard time adhering to ABS and if you sell these, the last thing you want are people complaining about the paint flaking off. If their existing door sill has scratched paint, they can simply use a spray can touch up paint in the areas of the cutouts and then apply your sill plate over the top.
[This message has been edited by IMSA GT (edited 05-08-2016).]
I tried that but it leaves the plastic too flimsy. I`m sure a lot of people`s rockers are like mine, they aren`t perfectly flat so with the flutes cut all the way through the middle kind of pushes up. I think the flute and the lettering cut very shallow, filled in with paint will almost be flush with the rest of the surface and look pretty good.
I will probably just sell these and let people paint them whatever color they want. I was playing around today and what I have found works the best is just tape the whole piece and then take a razor knife and carve out the letters and flutes. Then just spray it. When you remove the tape it looks really good. I don`t think flaking will be much of a problem because since it`s recessed the paint seems to stay down in there pretty well. My next big challenge is cutting out the patterns for using the pantograph so I don`t have to follow the pattern free-hand every time. I may check into getting a few graphics cut with a CNC.
[This message has been edited by TXGOOD (edited 05-08-2016).]
Well, I almost have my pantograph set up. I cut this one and painted it rather quickly just to see how it would look. I cut the F too deep so I didn`t paint it. When I get it set up to do on the sill plate I will route it better and take more time to paint it.
I`m not sure. I`m going to try a new method of taping and routing that will make it much easier to paint. I will be able to produce different patterns but I`m not sure at this point whether I will charge extra for that. I would imagine that "FORMULA" is something I would use more than once so it would not really be specialized.
I decided to cut the letters all the way through because its a lot easier to paint aluminum flashing the same color as the car and glue it underneath the plate with it showing through. This one I just left raw. I have not decided if I`m going to add flutes yet.
I would need to know the size of the part of the rockers that goes there unless it`s the same size as stock.
For mine and I need Quad to chime in, they are about 6-1/8 inches wide starting from the metal strip that holds the weatherstrip molding out to the outer edge of the sill. The lower panels on the IMSA's door extend past the sill plates so your plates can be as wide as you like.
