  Are these the Fiero GT rims?
Are these the Fiero GT rims? by james9937
Started on: 05-01-2016 06:21 PM
Replies: 10 (447 views)
Last post by: Patrick on 05-02-2016 04:04 PM
james9937
Report this Post05-01-2016 06:21 PM Click Here to See the Profile for james9937Send a Private Message to james9937Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was looking for some rims to replace the stock ones on my notchback and happened to find these.
I've managed to get three tires off, but the last one has a bolt that won't come off and the car's off the ground so when you try to loosen it the wheel just spins.
Any advice?
[This message has been edited by james9937 (edited 05-01-2016).]
David Hambleton
Report this Post05-01-2016 06:41 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could try this: Put one of the nuts back on another stud & put a breaker bar on it to prevent the wheel from turning when you reef on the one you're trying to loosen.
They look like pre '88 GT rims; in '88 the rears had the 1" lip at the face, the fronts have no lip.
Here's my '86 coupe with '88 GT (or Formula wheels):
And a close-up of my '88 Formula front wheel (no lip):
[This message has been edited by David Hambleton (edited 05-01-2016).]
Bruce
Report this Post05-01-2016 06:42 PM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
They certainly look like them. I think the specs are 5 x 110, but you can look that up here.
A little blasting and polishing would do wonders...
james9937
Report this Post05-01-2016 07:11 PM Click Here to See the Profile for james9937Send a Private Message to james9937Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you guys for replying so quickly I'll have to get a breaker bar soon.
Report this Post05-01-2016 07:19 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
5 X 100
luvfierosforever
Report this Post05-02-2016 12:07 AM Click Here to See the Profile for luvfierosforeverSend a Private Message to luvfierosforeverEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a locking lug nut and when purchase would have been supplied with a special piece to go over lug for removal. A lot of times it would get tossed in center counsel glove box, trunk in back, or trunk in front with the spare. Even the little spot on passenger side where glove spot should be. Check all over.
E.Furgal
Total ratings: 278
Report this Post05-02-2016 08:14 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
what are they on, now... as the g/p and bonntie have same type wheel but bigger lug pattern.. iirc 119x5 fiero is 100mm x 5
Report this Post05-02-2016 08:28 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by luvfierosforever:
That's a locking lug nut.
Looks like a normal nut, I think I can see the hex sides.
Khw
Total ratings: 134
Report this Post05-02-2016 09:44 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
I concur. Hex sides and center hole for the stud. Most "keyed" lug nuts don't have the center hole for the stud.
[This message has been edited by Khw (edited 05-02-2016).]
fierosound
Total ratings: 286
Report this Post05-02-2016 11:16 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Find a couple of spare tires or something laying around that is high enough to jam under the tire to hold it from spinning.
Report this Post05-02-2016 04:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree.
I'd spray the area with PB Blaster, jam something under the tire to stop the wheel from turning, put the other lug nuts back on (tightly), hammer the proper size socket onto the offending lug nut... and then twist that sucker off.
[This message has been edited by Patrick (edited 05-02-2016).]
