  changing the headlights in a 1984 fiero to gen 2
changing the headlights in a 1984 fiero to gen 2 by dasivesind
Started on: 04-21-2016 04:09 PM
Replies: 7 (183 views)
Last post by: Richjk21 on 04-21-2016 10:50 PM
dasivesind
Report this Post04-21-2016 04:09 PM Click Here to See the Profile for dasivesindSend a Private Message to dasivesindEdit/Delete MessageReply w/QuoteDirect Link to This Post
the donor car is a 1987 fiero do u have to change the wiring harness to hook up the new lights?
vette7584
Report this Post04-21-2016 04:46 PM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
yes
Richjk21
Report this Post04-21-2016 04:55 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
it has been done without changing the harness, but there is a lot of cutting and splicing involved..... It is actually easier in my opinion to change out the harness.
Rich
JohnWPB
Total ratings: 144
Report this Post04-21-2016 04:57 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
MUCH easier to change out the wiring harness as well. It is a quick and easy job if you swap in the Gen II harness, and only a single plug on the front "firewall".
mafv8
Report this Post04-21-2016 07:19 PM Click Here to See the Profile for mafv8Send a Private Message to mafv8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I modified my harness, was not hard to do, just followed the instructions by Dodgerunner, you can find these in the Ogres cave, at the time I did not have a harness available to swap, just motors and a module, works great.
84SE, aero body, 4 speed and an injected 355 V8
Report this Post04-21-2016 09:23 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
84 w/ AC means 2 speed radiator fan.
Switch whole harness to 87 means losing that to 1 speed. Likely need 87 fan w/o cutting wires.
See my Cave, Gen 2 HL Motor
Spiders1
Report this Post04-21-2016 09:27 PM Click Here to See the Profile for Spiders1Send a Private Message to Spiders1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did the entire harness. Very simple other than routing the wires under rad shroud. Tight area.
Richjk21
Report this Post04-21-2016 10:50 PM Click Here to See the Profile for Richjk21Send a Private Message to Richjk21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed.... worst part of the whole process!!
