  swaybar troubles
swaybar troubles by ztempleman
Started on: 04-19-2016 06:45 PM
Replies: 3 (138 views)
Last post by: tshark on 04-19-2016 07:57 PM
ztempleman
Report this Post04-19-2016 06:45 PM Click Here to See the Profile for ztemplemanSend a Private Message to ztemplemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I soaked the bolts in pb for 2 days and like everyone it seems, all 4 bolts broke off.
.......So like always came here as and will try my luck.
Cannot weld a nut onto any of them so.
1985 fiero gt 3800 s2 sc
tshark
Total ratings: 68
Report this Post04-19-2016 06:57 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm. Did you soak them top and bottom, multiple times per day? I usually use a torch to warm them up. I'm sure someone else will tell me this is all wrong, but it has worked for me.
Now that they're broken off, remove whatever is left, as well as the parts that broke off. Don't leave that stuff in the frame. You can get the bushings and probably the bolts from TFS. Rodney sells the bushings.
ztempleman
Report this Post04-19-2016 07:53 PM Click Here to See the Profile for ztemplemanSend a Private Message to ztemplemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yea soaked top and bottom but never heated them up but will keep in mind For next time.
I guess ima try flattening surface with dremel and try drilling a small hole centered and reverse bitwish me luck lol
tshark
Total ratings: 68
Report this Post04-19-2016 07:57 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use a punch and hammer to get out what you can.
