First
Page 1 of 1
Last
Goto
Boost bypass delete by Ryanap333
Started on : 04-04-2016 11:30 PM
Replies : 3 (186 views)
Last post by : IanT720 on 03-17-2017 08:39 AM
Apr 4th, 2016
Ryanap333 Member Posts: 182 From: Slocomb, al usa Registered: Jun 2015
Okay so from what i can tell il deleteing the boost bypass. I still have the hole in my supercharger and i need the block off plate. Also what else to i have to do as far as deletin the valve, silenoid, and actuator. I mean the actuator rod is moving something so do i have to do something there? I can find much on it.
11:30 PM
Mar 16th, 2017
Chaslam638 Junior Member Posts: 1 From: Crawfordsville, IN, United States of America Registered: Oct 2016
Were you ever able to find an answer to this? I have been researching this and have came up dry as well.
11:11 PM
olejoedad Member Posts: 20131 From: Back home again in Indiana Registered: May 2004
There is no performance gain to be had by eliminating the BBV. If you intend to do it, however, remove the solenoid and bracket, and immobilize the lever in the down position. Removing the lever, shaft and plate will by pass boost unless the plate opening is blocked off somehow. Again, no performance gain to be had by removal.....
11:17 PM
Mar 17th, 2017
IanT720 Member Posts: 1703 From: Whitmore Lake, MI Registered: Sep 2010
Remove the solenoid and screw in a bolt that holds the lever down. Double nut it. Super easy. No performance gain but it cleans up the engine.
08:39 AM
First
Page 1 of 1
Last
Goto
Advertizing on PFF | Fiero Parts Vendors PFF Merchandise | Fiero Gallery
