  Need a VIN# from a 2004 GTP Please (Just the first 9 digits)
Need a VIN# from a 2004 GTP Please (Just the first 9 digits) by JohnWPB
Started on: 03-17-2016 06:36 PM
Replies: 8 (225 views)
Last post by: JohnWPB on 03-21-2016 07:17 PM
JohnWPB
Total ratings: 144
Report this Post03-17-2016 06:36 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have no way of getting the VIN# for the donor car my engine came out of, as it was crushed. I do have the last 8 digits, and am tryong to compile the entire thing.
I need a VIN# from a 2004 GTP to work from. There are some things in the beginning of the VIN I am unsure of, such as Plant they were manufactured in, code for the restraint system, and a few other things.
I do not need the last 8 digits of your VIN#, so you can keep that private. I just need the first 9 that tell the country, plant, restraint system, body style and "carline/series".
thanks for the help in advance.
bonaduce
Report this Post03-17-2016 09:05 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
pm me the last 8, i can run it through my parts computer and get you the whole thing in the morning
dan
JohnWPB
Total ratings: 144
Report this Post03-17-2016 09:36 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! Pm sent.
Also, I am not worried who has the VIN number, as the car has long since been crushed.
Here are the last 8 numbers of the VIN:
24506029
Total ratings: 463
Report this Post03-19-2016 09:47 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
2G2WR524641120039
2G2WR524741357218
2G2WR524241132057
2G2WR524441100937
Ganked from cars.com
JohnWPB
Total ratings: 144
Report this Post03-20-2016 11:11 AM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! I think I was able to cobble together the VIN for the car my engine came out of : 2G2WR524X41193172 It passes a VIN decipher. I am going to wait till bonaduce runs the last 8 through a GM database, and see if that VIN he comes up with matches.
The numbers above are incorrect, as I took them off the wrong place on the engine.
The correct last 9 for my VIN are: 241193172
[This message has been edited by JohnWPB (edited 03-20-2016).]
bonaduce
Report this Post03-20-2016 04:17 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
logged in from home to get you the info, hope this helps
dan
2004 GRANP PRIX GTP
12U- GALAXY SILVER METALLIC
1SA - OPTION GROUP - 1SA
1SZ - PACKAGE SAVINGS
69B - DARK PEWTER
69I - DARK PEWTER
6KJ - COMPONENT FRT LH COMPUT SEL SUS
7KJ - COMPONENT FRT RH COMPUT SEL SUS
8DK - COMPONENT RR LH COMPUT SEL SUS
9DK - COMPONENT RR RH COMPUT SEL SUS
AK5 - DUAL FRONTAL AIR BAGS
AR9 - SEAT FRT BKT DELUXE
C67 - AIR CONDITIONER WITH ELECTRONIC CONTROLS
CF5 - POWER SUNROOF (DELETES OVERHEAD CONSOLE) POWER SUNROOF
DG7 - DUAL POWER SPORT MIRRORS
DL5 - DECAL ROADSIDE SERVICE
FE2 - SUSPENSION SYSTEM HANDLING
FE9 - 50-STATE EMISSIONS
FLT - FLT-FLEET ORDERS
FR2 - AXLE RATIO 2.93
IPB - TRIM INTERIOR DESIGN
JL9 - ANTILOCK BRAKE SYSTEM INCL. ENHANCED TRACTION SYSTEM
KCV - FLT-ALAMO RENT A CAR
KG7 - GENERATOR 125 AMP
L32 - 3.8 L 3800 SERIES III V6 SFI
MN7 - TRANSMISSION AUTOMATIC 4-SPEED
MX0 - 4-SPEED AUTOMATIC TRANSMISSION
N85 - WHEELS 17" CURVED 5-SPOKE ALUMINUM
NP5 - LTHR WRAP STEERING W/RAD CNTRLS
NT9 - FED EMIS SYS TIER 2 PHASE-OUT
NV7 - MSVA VARIABLE ASSIST STEERING
OST - OSHAWA PLANT #2
PEE - INTERNAL PROCESSING CODE
QNW - P225/55R17 BSW STL TOURING
R6F - IDENTIFY B CODE USERS
R8M - ALAMO/NATIONAL RENT-A-CAR TRACKING CODE
U1P - SOUND SYSTEM ETR AM/FM STEREO WITH CD PLAYER
U77 - REAR WINDOW ANTENNA
UE0 - ONSTAR NOT INCLUDED
UH8 - CLUSTER-COOL TEMPTRIP ODOM TACH
UW6 - 6-SPEAKER SOUND SYSTEM
V2G - CREDIT IN LIEU OF FUEL
V73 - VEHICLE CERTIFICATION U.S.
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR
VN9 - DAILY RENTAL REPURCHASE PROGRAM
YT1- DAILY RENTAL FLAT RATE DEPRICIATION
Vehicle Component
Component Code:  10-ENGINE ASSEMBLY
Traceability:  0779783
Source Plant:  B-BOC FLINT, MICHIGAN
Part / Number Broadcast:  BDH
Date Scanned:  09/12/2003
Time Scanned:  18:00:00
Scan Station:  03
Component Code:  35-STEERING COLUMN - SIR SYSTEM
Traceability:  OB1652513
Source Plant:  S-SAGINAW DIVISION SAGINAW,MI
Part / Number Broadcast:  UPC
Time Scanned:  17:24:00
Scan Station:  03
Component Code:  61-TRANSMISSION
Traceability:  0AZ5
Source Plant:  W-HYDRAMATIC WARREN, MICHIGAN
Part / Number Broadcast:  4CAB
Scan Station:  03
Component Code:  65-REAR AXLE ASSEMBLY
Traceability:  2553G0604
Source Plant:  0-
Part / Number Broadcast:  XD
Time Scanned:  20:55:00
Scan Station:  03
Component Code:  86-ELECTRONIC CONTROL MODULE (ECM)
Traceability:  13246RAPC
Source Plant:  M-DELCO ELECTRONICS MILWAUKEE, WISCONSIN
Part / Number Broadcast:  YDXH
Date Scanned:  09/13/2003
Time Scanned:  08:12:00
Scan Station:  03
Component Code:  AB-IR-MODULE ASM-INFLATOR
Traceability:  4234Z0264
Source Plant:  M-MORTON-THIOKOL
Part / Number Broadcast:  3477
Scan Station:  03
Component Code:  AL-IR-MODULE ASM-I/P
Traceability:  3230Z0408
Part / Number Broadcast:  3501
Scan Station:  03
Component Code:  AS-SENSING DIAGNOSTIC MODULE
Traceability:  132511XND
Source Plant:  K-DELCO ELECTRONICS KOKOMO,IN
Part / Number Broadcast:  3602
Time Scanned:  07:53:00
Scan Station:  03
Component Code:  CA-SEQ NUM (FLEX) BODY ASM
Traceability:  0561115
Source Plant:  O-
Part / Number Broadcast:  ZZ
Date Scanned:  09/11/2003
Time Scanned:  13:48:00
Scan Station:  03
Component Code:  CB-SEQ NUM (FLEX) BODY ASM
Source Plant:  -
Part / Number Broadcast:  2ZZ
Date Scanned:  09/05/2003
Time Scanned:  00:17:00
Scan Station:
Component Code:  CF-SEQ NUM (FLEX) PAINT PROCESS
Traceability:  2153160
Source Plant:  -
Part / Number Broadcast:  2PP
Time Scanned:  15:44:00
Scan Station:
Component Code:  CK-SEQ NUM (FLEX) GEN ASM
Traceability:  2160331
Source Plant:  O-
Part / Number Broadcast:  GA
Time Scanned:  15:55:00
Scan Station:  03
Component Code:  CP-SEQ NUM (FLEX) GEN ASM
Source Plant:  -
Part / Number Broadcast:  2GA
Scan Station:
Component Code:  CZ-SEQ NUM (FLEX) GEN ASM
Traceability:  043551
Source Plant:  -
Scan Station:  03
[This message has been edited by bonaduce (edited 03-20-2016).]
JohnWPB
Total ratings: 144
Report this Post03-20-2016 05:53 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
dan
Thanks for the info, but what it the VIN # ? The last nine digits I have for my VIN are: 241193172
There was a check sum error on the 9th digit of a reverse look up I did on the VIN above, so I changed that digit from a 4 to an X. I am not sure if it is 100% correct or not. That is why I was happy to hear you could get the full VIN from the last 8 digits. I am wanting to get the VIN so I can do a CarFax on it, to get approximate mileage and other info.
Thanks Again!
bonaduce
Report this Post03-21-2016 06:59 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
this is whatgm returns as your vin# when running the last 8
2G2WR524X41193172
dan
JohnWPB
Total ratings: 144
Report this Post03-21-2016 07:17 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought with the car crushed long since, in another state, getting the VIN would never be possible. With the tip from Olejoedad on where to find the last 8, and you looking it up made it all possible. Thank you, Thank you THANK YOU!
EDIT TO ADD:
This is definitely the VIN for this engine. It shows the car was purchased in 2004 in Florida, and then moved to TN for a few years. It then spent the last of it's life in Alabama, where the report shows that it was salvaged at Montgomery Pick-n-Pull in 2012. This where Joe said he bought the engine 3 years ago, so it all adds up.
My engine has 90,000 miles on it, and I am happy with that relatively low number.
[This message has been edited by JohnWPB (edited 03-21-2016).]
