   Choice of wheel, designing the car backwards
Choice of wheel, designing the car backwards by bigblockfieropacecar
Started on: 03-09-2016 11:46 PM
Replies: 25 (634 views)
Last post by: 2.5 on 03-24-2016 04:05 PM
Report this Post03-09-2016 11:46 PM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 88 Trans Am 15" wheels are really cool and appear to be a big brother of the 14 inch indy pacecar wheels.
Never mind the fact that they don't fit - - - for now.
The rubber that is typically on these wheels is typically 26.1 inches tall by 9.2 inches wide. That size would be perfect to fill up the wheel opening of the back of a 84 Indy pacecar.
Painting these wheels to match the 14 inch front wheels would be really cool and would make room for larger brakes.
Report this Post03-10-2016 12:37 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
viperine
Report this Post03-10-2016 01:34 AM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you like those, check out the '84 anniversary trans am wheels. White with a blue stripe, if I recall correctly. I have a set of '85's painted charcoal in the recesses with machined faces. They're referred to as salad shooters or 20 slot wheels. I use them for winter and swap over to snowflake wheels in better weather. If you want to get fancy, hawk's third gen parts now offers the GT diamond spoke wheel in 17x9, but again, made for trans ams. Wrong bolt pattern, and wrong center cap application. Oh well, one can dream, right?
IMSA/GT
Report this Post03-10-2016 07:38 AM Click Here to See the Profile for IMSA/GTSend a Private Message to IMSA/GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Contact Louis @ Centerline in California. http://centerlinewheels.com He can make your wheels with proper bolt pattern and any offset you need. He made mine which are both DOT and SF 15.1 approved. American made too. Some of their many styles with and without exposed centers:
http://centerlinewheels.com...20153618_saberii.jpg
http://centerlinewheels.com...0153624_scorpion.jpg
Report this Post03-10-2016 09:05 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm trying to keep my Indy pace car theme. If not for the availability of these 15" wheels
I would simply stay with 14 inch pace car wheels.
Report this Post03-10-2016 09:13 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 2014
If I understand this correctly, the bolt pattern is different and also the backspacing.
The first thing I need to do is fix the bolt spacing so I need to know if there is a wheel bearing Assembly selection that would upgrade my existing 88 bearings - - - some machining required I'm sure.
And then? Corvette rotors and calipers that fit inside the 15 inch wheels?
I don't know the possible interchanges that some of you have done on this forum,
I will be making shorter lateral bars so the wheel fits inside the fender well.
Report this Post03-10-2016 09:32 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, that 1984 anniversary Trans Am is what I'm trying to do and to somehow make my car look authentic as if it came this way from the factory. Well - - - and hide the engine.
Report this Post03-10-2016 09:37 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nobody has ever put that big a tire under the back of a fiero without putting the engine in the front.
This will be a first if I do it.
I do this sort of thing so yes I will do it.
Report this Post03-10-2016 11:51 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, I see now that rim is offered in a 16 inch diameter!
How did I miss that?
OK, yes, even more room for brakes.
The point of this post is that I really don't know what is available or the best way to go about this.
I'm looking for ideas but I am married to two things - - -
the Trans Am wheels, and the 88 fiero spindles.
imacflier
Report this Post03-10-2016 12:32 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changing the '88 to use the 4.75 bolt pattern is NOT trivial. FieroGuru has shown how here: https://www.fiero.nl/forum/Forum2/HTML/120747.html
And there is another method which I can't seem to find at the moment.
Good luck and mebbe you will find a simpler less costly approach!
viperine
Report this Post03-10-2016 01:34 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are at least 4 designs on the F-body 20 slot wheels. White, concave, convex, and 16". The 16 is only available concave...wheel adapters just might be the easiest route. The offset is going to matter as well, but I have no clue as to what extent... In my opinion, the 16" version is the ugliest (to each their own) as it added dimples and a different finish. As for concave/convex, the Fiero versions appear convex.
IMSA GT
Total ratings: 250
Report this Post03-10-2016 02:29 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have no idea if this will help you but there is a company that custom makes that wheel. If I remember, they take a 14" donor, cut out the face so you retain the bolt pattern, and make a 3 piece wheel in a larger size and whatever width you need. The wheels do look a little different with the rivets along the edges but they still look nice:
By the way, you have to have a translator to understand the Facebook pgae:
https://www.facebook.com/pa...Zbif/435223189880338
[This message has been edited by IMSA GT (edited 03-10-2016).]
Thunderstruck GT
Total ratings: 99
Report this Post03-10-2016 03:44 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't consider starting with the wheels, "designing the car backwards". Fact is, that is how it should be done.
Report this Post03-10-2016 04:40 PM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like the concave wheel almost better than the convex wheel but as far as backspacing my main consideration is that I want the inside of the tire to come very close but clear the stock 88 trailing arms.
The rest I will fix by altering the length of the lateral arms.
Report this Post03-10-2016 05:03 PM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
These wheels are going on the back,
Not the front.
Going onto Rear 88 uprights
qwikgta
Total ratings: 84
Report this Post03-10-2016 08:32 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
just be advised, the formula rims come in two diff offsets, diff front to rear.
Report this Post03-11-2016 10:06 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, your absolutely right but this pace car theme makes it more difficult.
Report this Post03-11-2016 10:07 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't know, that info gives me more options and will make this easier.
Report this Post03-11-2016 10:10 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are so cool looking, but it looks like big money. May even cost more than what I have into my entire Power plant.
Report this Post03-11-2016 10:19 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
My other outrageous plan is to possibly leave the stock 88 rotors and aluminum calipers for less unsprung weight and add an extra pair of rotors and calipers inboard and installed between where my axle shaft bolts to my outlet flange coming from my transmission differential. All four Calipers grouped together and designated as Rear proportioning.
Wouldn't that be cool? I think so and in some ways easier than the upgrade conversion I may otherwise have to do. These rotors would be nonvented and simply just a flat piece of laser cut steel although drilled and slotted.
[This message has been edited by bigblockfieropacecar (edited 03-11-2016).]
Report this Post03-11-2016 10:33 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
My other outrageous plan is to install some giant brake shoes from a semi that turn the inside surface of the wheels into a huge brake drum,
Lol, ok, just kidding.
Total ratings: 463
Report this Post03-12-2016 09:33 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. Except that GM did it bass-ackwards. The deeper dish wheels are the ones designed for the front.
The rears had a shallower dish (smaller lip.) This was supposedly done for front knuckle clearance.
I always wondered why they didn't just put the deeper dish on all four, and call it a day.
16" IROC wheels are the same way. Not that it matters here.
[This message has been edited by Raydar (edited 03-12-2016).]
qwikgta
Total ratings: 84
Report this Post03-24-2016 11:32 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know, I always found that funny that the deep ones were on the front. You don't know how many times I had to tell a tire/wheel shop to swap them back after getting new tires put on. Even had a set on my 79 Grand AM. but I had to put the front on back, and the back on front for that car. In the end I had to buy another set of front so I could run all 4 w/ the deep offset.
Rob
Jungle
Report this Post03-24-2016 02:01 PM Click Here to See the Profile for JungleSend a Private Message to JungleEdit/Delete MessageReply w/QuoteDirect Link to This Post
But not impossible. Are you thinking about how any changes of this nature will effect the ride/drive? When it comes to steering and turning, I like my car to feel true.
lou_dias
Report this Post03-24-2016 02:28 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
to support my racing, I'm looking for light-weight 16x10 wheels with 5.75" of back-spacing in either Fiero or F-body bolt pattern.
I am using bearings from Arraut Motorsports that come with the 5x4.75" bolt pattern currently.
Report this Post03-24-2016 04:05 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I always thought those dished T/A wheels would look great on Fiero.
