  Who was selling the 88 GT Oil Sender with an 87 pre-made connection?
Who was selling the 88 GT Oil Sender with an 87 pre-made connection? by robert1234
Started on: 03-05-2016 03:36 PM
Replies: 6 (145 views)
Last post by: robert1234 on 03-06-2016 04:19 PM
robert1234
Report this Post03-05-2016 03:36 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Who was it that was selling the 88 oil sender with a cable that was already made up for the 87 GT ? It was much lower cost than anyone else.
I saw it some where, but my eyeballs are sore searching for it. I thought I had it saved, but guess not.
Anyone remember ?
Total ratings: 463
Report this Post03-05-2016 05:46 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's a "how to", if you're interested.
http://www.gafiero.org/bbs/index.php?topic=1642.0
Report this Post03-05-2016 06:22 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Problem is most old sockets have problems too. Not just old senders. Means they can bite you in the long run.
Plugs are loose or rotted from rust are common issues. Fiero V6 OP sockets and senders get water, road salt, etc, thru engine vents.
Iffy connections can cause problems when OP sender is running the fuel pump.
splicing isn't hard. See my Cave, Oil Sensor
Use "water proof" crimps w/ heat-shrink & glue keeps out water.
robert1234
Report this Post03-06-2016 08:21 AM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi ogre,
Electrical is not a problem for me, I was just wondering because I saw it somewhere.
I have a new pressure sensor on right now, still acting up.
So, I'm going to bypass everything today and test the pressure directly.
Thanks
robert1234
Report this Post03-06-2016 08:39 AM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
robert1234
Member since Oct 2015
Can't I just disconnect the existing pressure sensor and install a cheap local gauge and +12V ?
Is there some issue doing this on a Fiero that I do not know of?
Report this Post03-06-2016 10:58 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't use electric if you have or suspect power/ground problems.
Use any mechanical gauge, 80-100psi minimum full scale.
Fiero FP relay works then system won't care remove the OP sender for testing.
robert1234
Report this Post03-06-2016 04:19 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used a mechanical gauge. Ran up to temp...worked very well.
So it has to be the sensor or the gauge.
I'll check the gauge sometime this week. As for that new 87 sensor, junk that thing and install an 88
I just wanted to make sure it was not a oil pump issue.
