  Fiero sitting for a year
Fiero sitting for a year by FireGirl
Started on: 03-03-2016 10:27 PM
Replies: 21 (418 views)
Last post by: FireGirl on 03-07-2016 05:40 PM
FireGirl
Report this Post03-03-2016 10:27 PM Click Here to See the Profile for FireGirlSend a Private Message to FireGirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally getting the fiero out again after it sat in the exact same spot for the past year. Was never turned on or moved.
Is there anything I should specifically check after having it sit through the winter? Tires are good, has new gas, battery is charged and I'll check the oil one of these days. I just commute 45 minutes each way to work and don't want it to break down because I forgot to check something. It's starting up and driving just fine around town, I'm so excited! But worried about longer, higher speed commuting!
Thunderstruck GT
Total ratings: 99
Report this Post03-03-2016 10:32 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It depends on how and where it was sitting.
My '88 GT was last driven in 1999. I'd throw a battery in it, maybe change the oil and run it.
All my vehicles sit covered up, in a heated shop with some of them on a carpet.
viperine
Report this Post03-03-2016 11:20 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tear into the heater ducting, and check under the rear/center console for evidence of rodent nests. Insulation being chewed up is a good indicator, and the resulting nest in the ducting can catch fire. Very well documented issue with Fieros that sat.
Shho13
Report this Post03-04-2016 12:05 AM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
My Fiero sits in the back of my driveway with a cover on it all winter, come spring time I take the blower motor resistor out and check for debris in the ducting. If there is any I use a coat hanger and GENTLY loosen it up and vacuum it up. Check wires, do a visual just to make sure there is no wires chewed through wherever you can see. (I found a mouse nest in between my tail lights last year!) Check the oil, as well as other fluids, and give it a start! Check around the distributer for an oil leak, as that distributor o ring likes to leak after drying up.
Since yours was stitting awhile, I would put a few gallons of fresh gas in the tank, just to make sure there is some volatility to it and have no problems starting it up on pure stale gas. One year really isn't all that bad.
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
spirit
Report this Post03-04-2016 09:24 AM Click Here to See the Profile for spiritSend a Private Message to spiritEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your brakes. Again check your brakes. The calipers have a tendency to lock up after setting. Mine did on the front only.
Thunderstruck GT
Total ratings: 99
Report this Post03-04-2016 09:37 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is why I said it depends on how and where the car is stored.
The brakes on my Pilot Vehicle were froze solid. The car sat in a barn.
I still can't believe I got the car off the trailer.
Oddly enough, it was only the fronts as well.
[This message has been edited by Thunderstruck GT (edited 03-04-2016).]
Gary W
Report this Post03-04-2016 01:29 PM Click Here to See the Profile for Gary WSend a Private Message to Gary WEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull the fuel pump or injector fuses and crank it until you get some oil pressure. Give the bearings a fighting chance.
Thunderstruck GT
Total ratings: 99
Report this Post03-04-2016 01:56 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's not a bad idea but the Pilot Vehicle sat for about 20 years.
I threw a battery in it and fired it right up like it was shut off 10 minutes ago.
Quite as a mouse!
jaskispyder
Total ratings: 205
Report this Post03-04-2016 02:10 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would do this after winter storage.
Thunderstruck GT
Total ratings: 99
Report this Post03-04-2016 02:24 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never had.
From my '62 Grand Prix to my '05 Dodge Magnum, they all were just fine.
Now, if it were an HHR well..........
FireGirl
Report this Post03-05-2016 03:22 PM Click Here to See the Profile for FireGirlSend a Private Message to FireGirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had it sitting outside on the gravel by some trees. Was under a cover the whole time and the cover was tightened underneath. Ive been driving it for short amounts of time with no problems. Oil pressure is great, ill just have to check its colors. Brakes work fine. I will check everything else mentioned. It just needs to stop raining!!
Edit: been a while since Ive worked with the fiero. How would I get into the heater ducting?
[This message has been edited by FireGirl (edited 03-05-2016).]
Blacktree
Total ratings: 350
Report this Post03-05-2016 04:33 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
To get at the heater ducting (to get leaves and stuff out), you can try removing the resistors and feeding a vacuum hose in there. This assumes your vacuum hose will fit in the hole. Plus, it might be difficult to get at all the junk in there.
You can also remove the blower motor, which will give you much more room to work. You just need to remove the screws around the blower motor, and it comes right out.
The resistors and the blower motor are both located in the front compartment, between the spare tire and the windshield.
Report this Post03-05-2016 04:45 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post03-05-2016 05:51 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, Parked where?
ground/grass then Tires likely have damage. Chemicals etc in dirt can eat tires parked for months.
Jack car so tires can spin. Look at tread for cracks in between areas hit the road.
Cracks here can cause tread separation, kill the belts, etc.
Example:
CLICK FOR FULL SIZE
Batteries hate you. If the dead one charges now... can be dead later w/o warning.
May have Brake issues/problems. Worse if parked outside.
FireGirl
Report this Post03-05-2016 07:05 PM Click Here to See the Profile for FireGirlSend a Private Message to FireGirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I removed the resistors and it looks spot clean! The coils and inside the hole. Should I remove the blower too to double check things?
FireGirl
Report this Post03-05-2016 07:20 PM Click Here to See the Profile for FireGirlSend a Private Message to FireGirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
FireGirl
Member since Jun 2011
Now my hood wont lock. Ideas?
Blacktree
Total ratings: 350
Report this Post03-05-2016 07:33 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try pressing down on the hood, directly above where the latch mechanism is. It may take some "oomph" to get it to latch. If that doesn't work, you can adjust the latch mechanism. I'm referring to the part of the latch that's in the chassis, not the part in the hood. IIRC, you can loosen 2 bolts and move the latch mechanism up a little bit. That should make it easier to close the hood.
FireGirl
Report this Post03-05-2016 07:36 PM Click Here to See the Profile for FireGirlSend a Private Message to FireGirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll try. I've had issues before but usually if I lift the hood higher or kinda throw it down when closing it, it would lock close. The locking part next to the windshield will move but doesn't "stick" in place.
Edit: Took a screw driver and pushed it down, locked just fine. Tried pushing on the hood above the latch, pretty much with all my body weigh but it still wasn't far enough. It locks, just not until a certain point of getting pushed down.
jscott1
Total ratings: 415
Report this Post03-06-2016 06:37 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check the latch inside the car. The cable can get stiff and the spring is not strong enough to retract the cable and the hood will fail to latch. If this is true then push the cable towards the hood and it will latch. Mine does this every time I open it. Slamming the hood will not help if this is the reason why it won't latch.
[This message has been edited by jscott1 (edited 03-06-2016).]
FireGirl
Report this Post03-07-2016 04:02 PM Click Here to See the Profile for FireGirlSend a Private Message to FireGirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you show me which two bolts? You're talking about the latch that actually locks the hood down, correct? The mechanism right next to the windshield?
FireGirl
Report this Post03-07-2016 04:05 PM Click Here to See the Profile for FireGirlSend a Private Message to FireGirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
FireGirl
The cable seems to work just fine. I can take a screwdriver and push down on the latch that locks the hood and it locks just fine. Then I pull the one in the car and it unlocks it just fine. It just seems like the hood isn't going down far enough into the latch for it to catch and lock into place.
FireGirl
Report this Post03-07-2016 05:40 PM Click Here to See the Profile for FireGirlSend a Private Message to FireGirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I figured it out! I did fiddle with the wire and it didn't work earlier. BUT I forgot I had always fiddled with a certain part of the wire, tried that and it closed just fine! Boy, being away for a year really rids you of those habits you always needed to do for things to work. Thanks for everyones help!
