I just use the bolt that hold it on to draw it back in place on my V6.
The problem with using the original bolt is that very few threads are engaged at the start. I found a much longer bolt which I use along with a nut. The bolt is screwed in until it bottoms out, and then the nut is turned to push the balancer into place on the crank.
I agree with Patrick. Many years ago, when I was doing my first 2.8 V6 rebuild, I tried to get away with just using the damper bolt. I noticed that the threads on the bolt were being deformed. I learned my lesson from that.
If you want to ruin a balancer, try using everything but an installer.
What's wrong with the method I outlined?
This is very similar to what I use and was describing above. How is this a problem?
[This message has been edited by Patrick (edited 02-18-2016).]
You didn't mention using a bearing which appears to work like the tool.
Let me clarify... that's an image I found on the 'net. I don't use a bearing, I use the factory heavy washer that is normally located between the head of the crank bolt and the balancer. However, for all intents and purposes, it's the same setup.
Originally posted by Thunderstruck GT:
But the installer is also a remover and a balancer should never have claws put on the outside of them like a pulley puller.
Well yeah... I agree that a balancer should never be pulled off with "claws". It should never be pounded off with a hammer either. But this thread is about installing a balancer.
I use the same method on the ls1 in the camaro. Start it with a longer bolt from the hdwr store, then torque it down with the old oem bolt, then install a new bolt.
