  1984 Throttle cable length
1984 Throttle cable length by bigblockfieropacecar
Started on: 01-22-2016 02:10 AM
Replies: 4 (397 views)
Last post by: Rodney on 01-23-2016 06:14 AM
Report this Post01-22-2016 02:10 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
how long is the stock throttle cable on a 1984 Fiero?
I don't want to disable my car just to find out the length and then sit around waiting for the new longer cable to arrive.
edfiero
Report this Post01-22-2016 05:38 PM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck finding a longer one. Most cars have a cable that is much much shorter.
Report this Post01-23-2016 01:36 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
That job really sucked. You really got to tear the car apart to get in there and work on that.
The cable ended up being 9 feet long. I didn't plan this job well enough and so I ended up stranded just like I hoped would not happen and my girlfriend had to come over and drive me around to get different parts.
I got the braided Spectra 3' cable from AutoZone and left the original sheth in place. Starting from the carburetor side I installed the braided cable then cut the stock sheathing where I wanted and coupled the two Sheaths together.
All done, the answer is 9' for my application.
Report this Post01-23-2016 01:38 AM Click Here to See the Profile for bigblockfieropacecarSend a Private Message to bigblockfieropacecarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 2014
Rodney
Total ratings: 267
Report this Post01-23-2016 06:14 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
One trick that might be helpful to some but too late for you is on my 88 Mera I moved my cruise control unit behind my trunk. The Mera is longer and behind the trunk under a cover is about a foot of unused space save the tail lights and reverse lights housings. I spent a length of time in a local junk yard and found a short cruise cable from some (probably GM) car. I made a bracket and inserted the existing cruise cable into one end and the short cable into the other end. It was steel. I probably drilled the ends and filed the holes to be square. Then I made some kind of clamp to clamp the 2 cables together. Works great for many years now. When I first bought my 88 Mera someone at a car show said that is a GM cruise control unit. So I hid it so no one would ever see it again.
Rodney Dickman
1988 Mera
