   Shifter and Select cable question 87 GT - 3 questions
Shifter and Select cable question 87 GT - 3 questions by robert1234
Started on: 01-04-2016 05:53 PM
Replies: 7 (191 views)
Last post by: robert1234 on 01-04-2016 10:17 PM
robert1234
Report this Post01-04-2016 05:53 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
I need new cables, yes Rodney.
But my question is ? Do the cables come with an adjustment or do they just install without having to adjust them?
If I need to replace one, seems like I should just do both while I'm doing it.....correct?
Also, is the shift kit worth doing as well?
3 questions....
Thanks
Report this Post01-04-2016 07:32 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the Getrag, there's an adjustment on one of the cables if I remember correctly.
I'd only replace the bad cable if the other one slides smoothly.
Is your shifter assembly loose?
[This message has been edited by Patrick (edited 01-04-2016).]
robert1234
Report this Post01-04-2016 08:01 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Shifter assembly is not loose, the car only has 78K on it.
Report this Post01-04-2016 08:24 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, that probably answers your third question then... as well as perhaps the second.
With my '88 Formula (same tranny as yours), the select cable is quite stiff and I should probably replace it, but the shifter cable is just fine.
robert1234
Report this Post01-04-2016 08:27 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, I'll replace the select cable then...thanks
Report this Post01-04-2016 08:36 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sure... assuming that's the cable that you're having an issue with. It usually is, as you'll notice the way it comes up from the bottom on the tranny end and is practically begging for water to gain access into it which in turn ruins its ability to slide smoothly.
robert1234
Report this Post01-04-2016 10:16 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Its the select cable. Its broken and not connected due to rust...yep, water / moisture damage.
robert1234
Report this Post01-04-2016 10:17 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
robert1234
Member since Oct 2015
I ordered an new one from Rodney
