| | | quote | Originally posted by tshark:
Chime dings intermittently
Fixes other than removing/disconnecting the chime. |
Don't forget throwing it as far as you can.
But the intermittent chime is alot of the time a loose e-brake switch.
Front turn signal bulb stays on, will not flash
bad bulb or bad flasher unit
Headlight motor issues, both 84-86 and 87-88
84-86 bad bushings, that caused striped gear, striped gear, bad relay, too soft of bushing replacement, dirty contacts on the relays.
87-88 bad bushings
Drooping headliners
replace it, go to an upholstery shop materiel is like $10
Power issues to the radio
bad grounds
Erratic oil pressure gauge
bad sender, prob leaks at this point
Temperature gauge fluctuations
melted connector, bad sensor
Symptoms of a bad ignition module
bucks, doesn't start, no check engine light
Cooling fan not coming on
temp switch, bad relay up front, then bad fan
Cigarette lighter failure
socket too tight and holds it too long and blows fuse, or too loose after useing a phone charger and doesn't heat up
Engine cranks, will not start, what to check first
Gas level, spark, then spray in starting fluid to see if gas is the prob.
Heater core failure, signs and replacement.
Easy, smells like anti freeze drips on passenger carpet.
Power windows slow
Dirty switches, old grease/dirt in the track, then old motor
No brake lights
Switch on the pedal
Dogbone wear and replacement
If the rubber is worn at all replace it, cheap, use a crescent wrench on the bracket to move the engine to help move to position
Brake issues with hose failure
one wheel either doesn't work of doesn't release, if it is leaking you will see it on the rim as strips
Taillight cover polishing
use Macguries Plastic-x
Sunroof rattling when in open position
worn headliner, missing plastic bushing under then handle or bent tabs
is that all of them?
"DRIVE IT LIKE A FIERO"
'84 Fiero,
engine to be determined '87 Duke (Sold)
'87 Quad 4 H.O. '87Blue GT 3.4L Swap Completed!!!!!!!! Boosted!!!!!!!^^^^ Now in the Construction Zone^^^^
Fiero Road Club Of Northern Nevada[This message has been edited by sardonyx247 (edited 12-19-2015).]
