  Exhaust manifold studs for 88 Formula. What is the recommended replacement type ?
Exhaust manifold studs for 88 Formula. What is the recommended replacement type ? by robert1234
Started on: 11-18-2015 08:39 PM
Replies: 8 (310 views)
Last post by: MulletproofMonk on 12-02-2015 12:29 PM
robert1234
Report this Post11-18-2015 08:39 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
And where to buy them?
fierogt28
Report this Post11-18-2015 09:35 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
The fiero store.
I bought the kit. Will install next time the engine is out.
fierogt28
88 GT, Loaded, 5-speed.
jaskispyder
Total ratings: 205
Report this Post11-19-2015 07:19 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any bolt or hardware store... or even Ebay, if you don't want to buy from Fiero Store. There is nothing special about the stud kit... standard items.
Thunderstruck GT
Total ratings: 99
Report this Post11-19-2015 09:03 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Contact ARP
They will have what you need and they are the best you can buy.
Report this Post11-23-2015 09:26 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just purchased stainless steel bolts and used them. They are still in place years later. Forgot the size but they may have been 8MM.
Thunderstruck GT
Total ratings: 99
Report this Post11-23-2015 09:47 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stainless has 2 issues though.
Stainless has a grade strength of just under a 5 and the threads cold weld (aka: gall).
Also, most stainless hardware is constructed out of 18-8 which is resistant to corrosion but susceptible to it. 316 stainless is highly corrosion resistant and 410 is more in the lines of a Grade 8 but not as resistant to rust as 18-8.
fast40driver
Report this Post12-01-2015 02:27 PM Click Here to See the Profile for fast40driverSend a Private Message to fast40driverEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just used 8mm hex socket set screws from (good) hardware store - easy to install/remove w/hex key, and grade 8 plus.
Mike
robert1234
Report this Post12-01-2015 05:10 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Mike,
Will those come out later? Seems like you would not be able to get them back out in a few years?
MulletproofMonk
Total ratings: 78
Report this Post12-02-2015 12:29 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.rodneydickman.com/n109.html
Fiero V6 Exhaust Manifold Stud Kit $15.00 plus $5.00 S&H
At this price, is it worth the risk versus pulling the whole motor later to drill out a bolt?
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
