  Help - Missing EGR Solenoid Bracket Bolt
Help - Missing EGR Solenoid Bracket Bolt by trivet
Started on: 11-14-2015 03:14 PM
Replies: 4 (426 views)
Last post by: trivet on 11-17-2015 11:38 AM
trivet
Report this Post11-14-2015 03:14 PM Click Here to See the Profile for trivetSend a Private Message to trivetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was trying to add an additional ground strap per the excellent instructions posted below. However, I am completely missing the bolt used to hold this bracket in place.
Does anyone have an extra, or know where a suitable replacement can be found?
Originally posted by $Rich$:
i added another Ground Strap
about a 6inch pc. of 4Ga. Wire that goes from the 15mm bolt that holds the EGR Solinoid Bracket on, to the bolt by the battery tray where the small ground wire is that comes off of the negative Bat. terminal with the 10mm bolt,
and my car runs ALOT smoother, it idles better, and seems to all arround have a little more Get up and go to it
i suspect that the stock one was just getting a little crusty, so i added another one and im amazed at the differance a 6" Pc. of wire has done!!!
somthing to think about
just thought id share
This is the bolt I am referring to:
Tim
'87 GT
Med Red Metallic
85K miles
Bay City, MI
tshark
Total ratings: 68
Report this Post11-15-2015 11:09 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
What holds your bracket on, then?
trivet
Report this Post11-15-2015 02:39 PM Click Here to See the Profile for trivetSend a Private Message to trivetEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is held in place by all the wiring. I never noticed it was missing until I went to add the ground strap
Report this Post11-16-2015 09:08 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump
trivet
Report this Post11-17-2015 11:38 AM Click Here to See the Profile for trivetSend a Private Message to trivetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know the size/thread of this bolt? I'm sure I can get a replacement locally if someone knows what the actual size is.
Thanks in advance for any help.
