  Engine Bay Insulator
Engine Bay Insulator by FieroFastBackL67
Started on: 11-04-2015 09:59 PM
Replies: 15 (554 views)
Last post by: FieroFastBackL67 on 11-07-2015 02:43 PM
FieroFastBackL67
Report this Post11-04-2015 09:59 PM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
What does everyone use in the engine bay with the 3800sc swap? Do I just buy a new stock fitted one? Couldn't find anything on this thought you all could help thanks guys.
hnthomps
Total ratings: 51
Report this Post11-04-2015 10:54 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used the foil backed insulation from WCF for the last three swaps. Two of them were 3800 SC engines. Similar material should be available from places like Lowes, Home Depot, etc. or maybe a local hardware or auto supply store.
Nelson
dobey
Total ratings: 371
Report this Post11-05-2015 09:27 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lizard Skin
Dynamat
Generic foil insulation like WCF sells and is available at a marine supply
Or nothing. Plenty just have painted engine bays, and a bit more insulation on the other side of the firewall, or between the main firewall and sheet metal overlay.
Rodney
Total ratings: 267
Report this Post11-05-2015 10:20 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Firewall and the shock towers. With no insulation there may be a slight increase of cabin noise. I don't think engine heat and the interior is much of a factor with or without the insulation on the firewall. IMO the insulation was more for lowering noise levels. Opinions?
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
TopNotch
Total ratings: 60
Report this Post11-05-2015 11:02 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used carbon fiber welding blanket, which you can get here. Withstands temperatures to 1800 degrees F.
You can get a template from fierosails.com for cutting it to shape.
dobey
Total ratings: 371
Report this Post11-05-2015 11:07 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've not got mine done yet, but I've definitely seen comments from others who have stripped the insulation and not added additional insulation on the other side of the firewall, who have reported definite heat radiation increase through to the passenger cabin; and comments where adding dynamat or such on the interior side definitely helps reduce heat as well as noise.
Total ratings: 260
Report this Post11-05-2015 07:29 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I use (1/2" thick version). It has multiple layers for both heat and sound control and has significantly more mass (and more expensive) compared to other material you can purchase locally.
http://www.westmarine.com/b...al--P006_180_006_004
[This message has been edited by fieroguru (edited 11-05-2015).]
Total ratings: 466
Report this Post11-05-2015 07:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
WEST MARINE Noise Control Barrier Material
I was reading reviews of the product at the site you linked to. There seem to be multiple complaints about "separation" of the layers. Have you experienced any such issues?
CarolinaRigman
Report this Post11-05-2015 08:33 PM Click Here to See the Profile for CarolinaRigmanSend a Private Message to CarolinaRigmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
With these insulation choices, whichever you prefer, with a 3.8 or LT1 swap
are you eliminating the metal shield and these materials withstanding the heat?
I was looking at a small air deflecter to move some of the airflow beneith the
body up through the already vented hood area.
I'm considering a turbo 2.8 or an LT1 swap in the future, both of them in the shop.
Just looking for input.
Make any sense at all? Lol
Total ratings: 260
Report this Post11-05-2015 08:38 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope.
fireboss
Total ratings: 58
Report this Post11-05-2015 09:51 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lizard Skin
Dynamat
I have used Dynamat/Fatmat on the exterior firewall and interior firewall and then added the foam floor squares pecies they sell at Home depot for garage floors on top of the mat on the inside firewall ...it all works great together
these are the foam squares I am referring to
Would love to do the next engine bay with that lizard skin though.
[This message has been edited by fireboss (edited 11-05-2015).]
dobey
Total ratings: 371
Report this Post11-05-2015 10:31 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm going with spray/brush-on sound dampener and insulation, and swapping in an LS4.
fireboss
Total ratings: 58
Report this Post11-05-2015 11:00 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mickey_Moose
Total ratings: 145
Report this Post11-06-2015 01:13 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any auto body supply shop should have some "hood insulation" - same stuff if you are looking for something along the original looks, just cut to fit.
Here is an eBay link: http://www.ebay.com/bhp/under-hood-insulation
CarolinaRigman
Report this Post11-06-2015 02:59 PM Click Here to See the Profile for CarolinaRigmanSend a Private Message to CarolinaRigmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! That looks like the stuff. Not a bad price at all!
FieroFastBackL67
Report this Post11-07-2015 02:43 PM Click Here to See the Profile for FieroFastBackL67Send a Private Message to FieroFastBackL67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you everyone this is all great help. Very appreciated!
