  fiero indy valve cover paint and decals
fiero indy valve cover paint and decals by vette7584
Started on: 10-31-2015 08:07 AM
Replies: 2 (646 views)
Last post by: RAREW66 on 10-31-2015 01:08 PM
vette7584
Report this Post10-31-2015 08:07 AM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
does anyone know the best color match for the indy valve cover and air cleaner? does anyone make good decals? thanks!
johnt671
Report this Post10-31-2015 09:50 AM Click Here to See the Profile for johnt671Send a Private Message to johnt671Edit/Delete MessageReply w/QuoteDirect Link to This Post
Paul at Fiero sails sells a decal or a stencil for the Indy. I don't know the colors.
RAREW66
Total ratings: 78
Report this Post10-31-2015 01:08 PM Click Here to See the Profile for RAREW66Click Here to visit RAREW66's HomePageSend a Private Message to RAREW66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a copy of the information that I send out when I get asked about this subject. The tips I give are from doing this for many years to replicate a correct restoration.
The Indy Valve Cover and Air Cleaner paint codes:
For quality Automotive Paint, It is a Chrysler color, CA1 Radiant Silver
Chrysler Code DT 9049
PPG Code 3556
Duplicolor makes a spray can version in either codes:
DSCC 338 Radiant Silver
DSGM 340 Silver Metallic
Spray can paint is close in color and texture, but leaves a little to be desired in a perfect replication and the spray can paint will not last as long.
Some notes for correct duplication:
1) Spray the silver over black primer or paint as the originals were dipped in black paint before being sprayed silver. The factory just grabbed standard iron duke valve covers and air cleaners out of the production parts bin and sprayed them silver.
2) The original paint was enamel, so if spraying urethane based single staged paint with a gun, reduce the gun pressure and increase the spray distance and spray pattern width to duplicate correct texture. And spray the parts like you have been standing on an assembly line all day and it is almost five o'clock with a pretty girl and free beer waiting for you at the bar after work. Thin spots, runs, sags and dirt particles in the paint are normal.
3) Paul KcKibben of Fiero Sails makes an excellent duplicate graphics kit in decal form or a reverse image mask that you can use to replicate the original screen printed graphics with an airbrush. http://www.fierosails.com/decal.html
Fred
