  New factory spec carpet??
New factory spec carpet?? by cam-a-lot
Started on: 10-31-2015 07:42 AM
Replies: 5 (258 views)
Last post by: dobey on 10-31-2015 11:10 AM
cam-a-lot
Total ratings: 97
Report this Post10-31-2015 07:42 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.ebay.com/itm/Pon...kt%3D8%26sd%3D151863 597326
Has anyone bought from this vendor? If so, how was the fit and finish?
dobey
Total ratings: 371
Report this Post10-31-2015 09:00 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't know where that vendor gets their carpet supply from, but that picture is definitely not an OEM spec carpet for a Fiero.
I'm pretty sure they're just selling the same standard replacement carpet that Stock Interiors and everyone else sells, and it's not the same as OEM.
Total ratings: 463
Report this Post10-31-2015 09:00 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like the AA(?) carpet that many of us are familiar with. Ships from Wedowee AL, which is not too far from Anniston (where the other place was/is.)
Also appear to be affiliated with Choo Choo customs, who used to do a lot of custom vans and El Caminos. (If you can believe what they posted. Of course nobody ever "copy-cats" on eBay. )
[This message has been edited by Raydar (edited 10-31-2015).]
rogergarrison
Total ratings: 551
Report this Post10-31-2015 09:41 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
In their defense, the ad says 'made to factory specs'. I didnt see where he said its OEM. All that means is quality is equal to or better and is premolded to fit correctly. Ive installed lots of aftermarket car carpets and most have dropped right in, but all ends still need to be trimmed after installed. You also have to cut any holes like for consoles and seat mounts. Your not going to find one that just sets in and your ready to go.
dobey
Total ratings: 371
Report this Post10-31-2015 11:05 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, "Choo-Choo Automotive Styling" isn't quite what "Choo-Choo Customs" once was, but the carpet coming from that seller is legit.
http://choochooauto.com/epa...87/Products/CH-PC001
But the carpet is indeed the same as the "Stock Interiors" and others. It seems the Fiero carpet is probably simply not stocked in the Choo-Choo facilities in TN, and is probably drop-shipped from their supplier in AL.
dobey
Total ratings: 371
Report this Post10-31-2015 11:10 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
Well, it's not "made to factory specs" though. It is "made to factory dimensions." It is thinner and the fibers are nowhere near the same quality as OEM. It might be similar quality to some OEM carpets in other cars, but it doesn't feel or insulate anything like the OEM Fiero carpet does. The vinyl heel mat is also often poorly attached to these replacement carpets, and is inferior to the factory vinyl heel mat.
