  87 duke into an 84. (Page 2)
87 duke into an 84. by Josh52894
Started on: 10-14-2015 01:37 AM
Replies: 46 (1041 views)
Last post by: Josh52894 on 05-19-2017 08:16 PM
dratts
Total ratings: 119
Report this Post05-15-2017 09:40 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I purchased an 84 a while back and I can see a lot of new parts that the previous owner installed. I'm trying to decide whether to pursue the repair or get a different engine. If I replace the 2.5 will I have to use an 84 engine to avoid all of this. Thanks
Josh52894
Report this Post05-15-2017 09:42 PM Click Here to See the Profile for Josh52894Send a Private Message to Josh52894Edit/Delete MessageReply w/QuoteDirect Link to This Post
if i were you i would definitely use an 84-86 iron duke with a distributor. they are all the same. this was way too much of a hassle for what it was worth.
dratts
Total ratings: 119
Report this Post05-15-2017 09:58 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, would it have to be a Fiero engine?
Total ratings: 567
Report this Post05-15-2017 11:41 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
No but FWD cars w/ VIN R engine are setup w/ PS pump etc so you have to change alt and other brackets for Fiero.
84 engine have some parts different vs 85-86.
You can swap whole engine but internal block and some parts are different.
See my Cave, Duke Quick Ref
Josh52894
Report this Post05-19-2017 01:00 PM Click Here to See the Profile for Josh52894Send a Private Message to Josh52894Edit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/adgLrYIcoUM
Link to drag strip run in case anyone wants to see what an iron duke fiero looks like going down the dragstrip.
Total ratings: 458
Report this Post05-19-2017 04:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Damn that duke sounded great for the first six or seven seconds!
[This message has been edited by Patrick (edited 05-19-2017).]
Josh52894
Report this Post05-19-2017 08:16 PM Click Here to See the Profile for Josh52894Send a Private Message to Josh52894Edit/Delete MessageReply w/QuoteDirect Link to This Post
its the cat delete really gives it a nice rumble. thanks for linking that correctly.
[This message has been edited by Josh52894 (edited 05-19-2017).]
