  Relocating Coil
Relocating Coil by 85fieroguy
Started on: 08-28-2015 06:47 PM
Replies: 1 (151 views)
Last post by: hyperv6 on 08-28-2015 09:43 PM
85fieroguy
Report this Post08-28-2015 06:47 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have a MSD blaster coil, finishing up exhaust manifold gaskets ( don't ask I almost lost my mind), wondering about guys saying to relocate it because of the heat. Does it make sense to locate it on the trunk storage wall facing the engine, or ( with holes drilled) put it inside the trunk ( indentation). Obviously you will need a longer distributor to coil wire and lengthen the others. Whats your take on this ???
hyperv6
Total ratings: 93
Report this Post08-28-2015 09:43 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Best to put it inside the trunk. GM in their performance and the PPG pace cars always put the coil and ignition box inside the trunk to protect it from the heat.
