  Replacing exhaust manifold parts
Replacing exhaust manifold parts by 85fieroguy
Started on: 08-26-2015 01:08 PM
Replies: 2 (201 views)
Last post by: 85fieroguy on 08-26-2015 06:18 PM
85fieroguy
Report this Post08-26-2015 01:08 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
....me think I'm loosing my mind !!!!..doing a gasket replacement on my 85 V-6, and the PM Blaster does help to a point, but broke a bolt on one stud ( below # 5) and the spring/bolt on the crossover..... getting the heat shields off was a challenge. Cleaning parts and using VHT to clean up appearance...replacing O2 senor, bolts, EGR gaskets , plugs and wires. QUESTION????...when replacing parts, should I use LOCTITE RED (high heat) on all the exhaust bolts or is anti-sizing good enough ???...should be done by Christmas
Report this Post08-26-2015 01:56 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd use anti seize.
Says "Temperature range: -60°F to 1600°F"
The Loc Tite I looked up as "red" said "temperatures of up to 450 degrees F" on an exhaust manifold you need more like 1500 degrees.
[This message has been edited by 2.5 (edited 08-26-2015).]
85fieroguy
Report this Post08-26-2015 06:18 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info Masked Avenger !!!!!
