  Got it running right!
Got it running right! by tnkgnr
Started on: 07-20-2015 09:44 PM
Replies: 4 (242 views)
Last post by: MadProfessor8138 on 07-22-2015 06:40 PM
tnkgnr
Report this Post07-20-2015 09:44 PM Click Here to See the Profile for tnkgnrSend a Private Message to tnkgnrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just sharing my joy and my story.
So I bought my 86 SE 5sp nearly a year ago. Has a 3.4p/r swap and an 88 cradle in it. Picked it up for $1800 as it needed exhaust work, threw a bunch of codes (I think 4 different ones) and was always winking (one working headlight).
- Drove it home and broke down on the way - couldn't figure it out...would crank, had fuel, every once in awhile it would barely fire. Towed it home...turns out the little graphite nub on the distributor cap was broken (with evidence piece found in the cap).
- Took apart the headlight mechanism (there was nothing wrong internally), but it must have just been a loose connection because when I plugged it back in, it worked! Winking headlight fixed.
- Car came with a new fuel filter, so figured I would throw that on...of course even when using two wrenches, the fuel line split...bought some stainless braided line and replaced that whole segment that runs into the right side of the filter - looks better and was less than half the price of an OEM replacement. No problems so far.
- I thought it needed a little exhaust work, but it needed a lot...replaced everything behind the Y-pipe. It was such a pain in the ass...
- Had to dremel the bolts back into hex shapes and use those extractor sockets to budge em.
- The O-2 sensor was seized like crazy - two weeks of pb blaster and a breaker bar wouldn't budge it. Even with a 4ft cheater pipe it didn't do anything. Thought maybe the socket was expanding, so bought an impact socket and it moved first try.
- Just when I thought I had the exhaust figured out, I took it for a test drive and my pipes disconnected right behind the Cat and drug on the ground - I pulled it up a bit with lacing wire to limp home, but my garage has that lip as you enter and it caught one of the clamp bolts and bent the pipe all the way around. Fortunately I was able to grunt, pull, and kick the pipe back into shape with the cheater pipe. Put a much longer coupling in there and cranked down the clamps tighter so that shouldn't happen again.
- Timing...holy cow, this took awhile
- Marked the fat mark on the harmonic balancer, did timing procedure and didn't see the mark at all.
- Checked the firing order - was definitely not in order, but it ran - I think it was 180 degrees off
- Pulled the #1 plug, set it at TDC and put everything in order
- Timing bounces between 12 and 8, so I'm thinking a new timing chain is in my future, but it's all set right now
- Spiders!
- Man, there was a crap ton of spiders all around this car. Mostly couldn't see them, but every day I would go into my garage and see a bunch of webs everywhere - mostly from the car to the ground.
- Tried sweeping out the webs for a couple weeks, but they were relentless
- Sprayed some Ortho Home defense all over the undercarriage. Came out that night and found a few of those punks hanging down. Two of them were Black Widows! One had it's hangout right where I go under the car...so that was creepy.
Took it for a test drive today - I've got power, my exhaust doesn't stink, it's not pissing off the neighbors, and there were no check engine lights Feels really good when it all works just right!
mrfred8
Report this Post07-20-2015 10:18 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats! What a great feeling to finally get everything dialed in.
Shho13
Report this Post07-20-2015 11:03 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Black widows!!! Holy cow!!
The only Black widows that I would like to have in my car is my old reliable bowling ball I've had since high school!
Congrats on getting everything going right!!!
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
tnkgnr
Report this Post07-21-2015 10:30 PM Click Here to See the Profile for tnkgnrSend a Private Message to tnkgnrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yea, black widows...I feel paranoid every time I get under the car now, which has been very often!
MadProfessor8138
Report this Post07-22-2015 06:40 PM Click Here to See the Profile for MadProfessor8138Send a Private Message to MadProfessor8138Edit/Delete MessageReply w/QuoteDirect Link to This Post
It must be a Fiero thing......I finally started working on one of my cars about 2 weeks ago and low and behold....one of the biggest damn black widow's that I have ever seen had made home on the back side of the drivers side rear wheel.
Needless to say,one of us had to go.....with prejudice !!! Lmao
