  Head lights
Head lights by Klondike
Started on: 05-15-2015 03:34 PM
Replies: 2 (144 views)
Last post by: Klondike on 05-15-2015 04:54 PM
Klondike
Report this Post05-15-2015 03:34 PM Click Here to See the Profile for KlondikeSend a Private Message to KlondikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The problem is ONLY on the driver side - the passenger side head light works fine. The driver side head light on my '88 Fiero does not quite raise all the way UP when the head lights are turned "ON." When the head lights are turned "OFF," the driver side light fully retracts to the stowed position. I noted the passenger side head light cannot be moved by hand (and, the manual option for opening and closing the passenger side head light works fine). However, I noted when I attempted to physically raise the driver side head light, I could move it freely by hand. I'm looking for some technical help with the driver side headlight. Thanks!!
Report this Post05-15-2015 04:00 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
On the gen2 headlights....87 and 88, The drive rollers fall apart. Usually things are OK if you replace them....
http://rodneydickman.com/ca....php?products_id=231
Klondike
Report this Post05-15-2015 04:54 PM Click Here to See the Profile for KlondikeSend a Private Message to KlondikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! I suspected that was the "fix," but was hoping there was a way to adjust without needing to rebuild!!
