  Is this the rear strut bumper? Boot seems to be missing...
Is this the rear strut bumper? Boot seems to be missing... by rednotdead
Started on: 05-15-2015 05:22 AM
Replies: 3 (199 views)
Last post by: rednotdead on 05-15-2015 08:24 PM
rednotdead
Report this Post05-15-2015 05:22 AM Click Here to See the Profile for rednotdeadSend a Private Message to rednotdeadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another noob question of mine: before I shell out 45 bucks for a set of strut boot/bumpers, I'm hoping to confirm that Im buying the right parts. Here is the degraded looking part on my car that Im guessing is the stock bumper without the boot, I'm looking to replace this when I install my KYB's. Also, what other wear items would be a good idea to examine/replace when I pull this apart?
Many thanks
FIEROPHREK
Total ratings: 137
Report this Post05-15-2015 12:24 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes thats the bumper
12.3 is faster than a 13.2
Report this Post05-15-2015 12:41 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
So you are replacing struts, you could replace the strut mounts and springs but many times you dnot need to on a Fiero as they dont rotate like many cars with front struts. The springs I have not replaced either. Even if they are tired it just means you are little lowered.
Otherwise its a good time to clean and maybe paint stuff in that area. Check out suspension bushings, etc.
rednotdead
Report this Post05-15-2015 08:24 PM Click Here to See the Profile for rednotdeadSend a Private Message to rednotdeadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The springs are out, since I can't locate any non-lowered versions for the '88 and I'm not up to cutting anything. Strut mounts however... is there any way to determine if they've gone bad without disassembling everything? I've got no garage and I'm not able to leave my car in a state of un-roadworthiness for more than a single night. And at more than 50 bucks a pop I'm hesitant to replace it "just because".
I'll try to paint the springs at least, they look terrible at the moment. Would rustoleum rubberizer undercoating be up to this task?
