Update System
  Th440 4T60 swap help with parts needed
by NeoMike
Started on: 03-26-2015 09:01 PM
Replies: 4 (1081 views)
Last post by: NeoMike on 06-05-2015 09:38 PM
NeoMike
Report this Post Click Here to See the Profile for NeoMikeClick Here to Email NeoMikeSend a Private Message to NeoMikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Everyone,
I've got a TH440 transmission that I'm going to put into my 88 Formula to replace the TH125. I've done some reading and am wanting some input from you guys to be sure that I'm getting the other parts needed to install the transmission.
CV axles:
I found on http://snowcloude.com/~banner/FIERO-4T60.html that ones out of an 87 Pontiac 6000 part number 5257 and 5258 are supposed to work. I find on http://www.pontiacperforman...es/4_speed_swap.html that Cardone part numbers 60-1078 and 60-1115 will work. Can anyone let me know if these part numbers are correct or if you have some others?
Transmission mounts:
I found http://www.fierofocus.com/T...%20Transmissions.pdf , It tells me that a 1992 Pontiac Bonneville (3800
vin L) work in Fiero applications, and the OE/stock Fiero rear transmission mount will work on the back of this transmission as long as you have the formed/stamped steel bracket from a donor Bonneville or like-bodied car that bolts to the left-rear of the transmission.
Am I missing anything else that I need? Any help is greatly appreciated.
Thanks,
Mike
randye
Total ratings: 205
Report this Post Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shift cable bracket and shift arm modification:
Trans. to engine block mount modification for 2.8 and 3.4 engines:
[This message has been edited by randye (edited 03-27-2015).]
NeoMike
Thanks
NeoMike
I found the GM part number for the transmission mount bracket mentioned in http://www.pontiacperforman...es/4_speed_swap.html. The GM part number is 22145828, which has the bracket as part of the mount.
NeoMike
I had to order a governor assembly for my 4T60 transmission since it was the one that wouldn't work with the Fiero. I ordered the parts from http://www.txchange.com. I paid $40 for the parts and $14.72 for UPS shipping to South Carolina. Their part number for the governor assembly is RK84410
PFF Merchandise | Fiero Gallery | Fiero Headlight Control Module
