The motor to lift mounting  bolts? And you have Gen 2 motor?
1/4" longer Bolts then likely to mount gen 1 motors. Gen 1 motor holes are 1/4" longer and likely need longer bolts.
I have both motors... (I have gen 1 and 2 mounting bolts but not digging thru everything to find the bolts.)
gen 1 long holes are 2 15/16", gen 2 long hole = 2 11/16, dif is 4/16"=1/4"
Short holes have same dif but didn't measure them.
If they bind and you need them then cut as needed to stop binding.
