  Paint or not to Paint Calipers
Paint or not to Paint Calipers by TheDave
Started on: 03-05-2015 10:56 AM
Replies: 22 (1101 views)
Last post by: Fiero84Freak on 03-12-2015 09:45 AM
TheDave
Report this Post03-05-2015 10:56 AM Click Here to See the Profile for TheDaveSend a Private Message to TheDaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I am replacing all 4 calipers with reman units. Should I paint them or not. Does it look goofy on stock brakes? Here is my 17" wheel setup. If so what color?
Regards,
David
88FieroGT TTops
Report this Post03-05-2015 11:33 AM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Red?
TXOPIE
Report this Post03-05-2015 11:42 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
David...Is that an 87 or 88?
If 88 and as nice as your car looks...I personally would powder coat them in a chrome and then a 2nd custom color transparent powder coating.
TheDave
Report this Post03-05-2015 12:16 PM Click Here to See the Profile for TheDaveSend a Private Message to TheDaveEdit/Delete MessageReply w/QuoteDirect Link to This Post
TX Opie it is an 87 and thanks for the kind words on my car. I like that idea on powder coating. I did some google research on that and the outcome would look really cool. Was thinking of keeping a darker color (shows less dirt). I kind of like the looks of this color combo. Super Chrome and what ever that red is. This color is just for the calipers and not for the rims. The rims are staying as is. I called a local powder shop and it would be about $175 for just one stock color that they have available and he said that to go the route that was suggested would be around $450 or so. I think keeping it below $200 is more my range. Can it be done as you thought for that price?
Regards,
David
[This message has been edited by TheDave (edited 03-05-2015).]
css9450
Total ratings: 87
Report this Post03-05-2015 12:39 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I painted mine just to keep the steel (or is it iron?) parts from developing surface rust. I've seen some remans which turned rusty in a shockingly quick time, but that probably depends on who rebuilt them and what kind of rust preventative they got, if any.
Mine have the stock GT 15" wheels so the painted calipers are only barely visible. Its an '88 if it matters.
dobey
Total ratings: 371
Report this Post03-05-2015 01:08 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock calipers should be aluminum, so rust isn't really an issue, though they can get the oxidized layer after a while and start looking nasty. Paint really helps with that.
Just do black, or even just a high temp clear, if you're worried about them standing out too much with stock brakes. A non-gloss black will keep them low key.
css9450
Total ratings: 87
Report this Post03-05-2015 01:42 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by dobey:
The stock calipers should be aluminum, so rust isn't really an issue...
88s... The outer "bridge" part is iron.
TXOPIE
Report this Post03-05-2015 01:42 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dave here is how mine turned out:
rogergarrison
Total ratings: 551
Report this Post03-05-2015 03:11 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
These days, I like just 'cast' colored paint on them. The bright red, orange and yellow dont do a thing for me, but thats just my taste.
JohnWPB
Total ratings: 144
Report this Post03-06-2015 12:36 AM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will powder coating hold up on brake calipers? I know special caliper paint is usually ceramic based and can handle up to 1200 degrees or so. Powder coating is just plastic, and melts at 300 degrees.
Zack_White86gt
Report this Post03-06-2015 01:59 AM Click Here to See the Profile for Zack_White86gtSend a Private Message to Zack_White86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't trust reman units and have had many defective ones. You run the risk of being out of warranty if you paint them. That is the main concern I have.
Total ratings: 466
Report this Post03-06-2015 02:23 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just in case you might find this helpful...
Originally posted by Patrick HERE:
I bought the cheapest red metal paint (a knockoff of Rustoleum) that I could find at either Home Depot or Rona, and it's been fine for five years on the aluminum calipers on my '84 (and '86 GT). A year ago I used the same paint on the steel calipers of my '88 Formula... same measure of success. No rust. All I did to prepare the calipers for paint was to apply acetone with an old toothbrush and wipe them down. It's not spray paint, it was brushed on (two coats). Maybe that's the secret.
Someone "warned" me that this paint wouldn't stand up to the heat generated by the brakes. Four years of autocross with the '84 and one year of autocross with the '88 have proven otherwise.
It's called Armor Coat, and the (just under) 1L can at Canadian Tire is currently priced at $8.99... quite a bit cheaper I believe than other rust paints. No primer is necessary, and it's held up very well.
I used "Fire Red" on the calipers, and after painting 12 of them, I still have half a can of paint left.
dobey
Total ratings: 371
Report this Post03-06-2015 09:35 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Powder coating is just finely ground powder. There are powders for high temp applications, even on headers. http://hp-powdercoatings.com/
rogergarrison
Total ratings: 551
Report this Post03-06-2015 10:44 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless your driving competitively, your calipers dont get hot enough for high heat paint. I painted mine for years with Krylon or Rustoleum spray cans and lasted just fine for several years. I did one set on one of my Corvettes with Caliper Paint, and it didnt last any better and was much more of a hassle to do. They needed like 10 coats to cover, where spray can did it easily in one or two.
spirit
Report this Post03-06-2015 10:56 AM Click Here to See the Profile for spiritSend a Private Message to spiritEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used hi-temp paint in a can and brushed it on the calipers with an artist brush. I did it with the wheels nd brakes on the car. It has beenabout 5 years ago. I touch them up every so often. Worked great.
dobey
Total ratings: 371
Report this Post03-06-2015 01:06 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You mean the brush-on caliper paint kit? Yeah, that is crap. Avoid that.
The VHT High Temp Caliper Paint in a spray can works well though. I haven't painted any calipers with it yet, but I've painted an intake and a valve cover using it, and it works great. Just needs a couple of coats like any normal spray.
And for the calipers getting hot, yeah, the calipers themselves aren't going to get too terribly hot, even if you track the car. The rotors and pads are where the heat is, and the pads don't have a decent contact patch with the caliper body to heat them up. If your calipers are hitting 1200F, you will need to be worrying more about being able to stop, than whether the paint or powdercoat is going to burn off, since the fluid will basically be vaporized inside the calipers at that point.
rogergarrison
Total ratings: 551
Report this Post03-07-2015 05:25 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
My motorhome has some problems on long, twisty, hilly back roads. The power brakes booster is operated from the power steering pump. It get a workout on one of those roads and the master cylinder overheats causing the front brakes to be a little erratic. Im going to put an aftermarket trans cooler in the steering hose line that I hope fixes it. I already wrapped the master cylinder with heat wrap. Its fine on highways or city drives.
dobey
Total ratings: 371
Report this Post03-07-2015 08:18 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had motorhomes pull off the interstate and merge in front of me before, and their brakes were so hot I could smell them. Had to let one know a few months ago, because I don't think the people inside it knew their brakes were overheating.
rogergarrison
Total ratings: 551
Report this Post03-08-2015 01:14 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
This happens to me when I even barely use the brakes at all. I use the gears a lot to control speed too. It seems to be caused more from the constant steering than using the brakes. The calipers dont get overly hot, its the master cylinder. First time it did it, the fluid in the MC was even boiling and overflowed when I took off the cap. Its a truck P30 chassis and dealers tell me its not unusual with the type of booster. I can go 500 miles on the freeway, or across the city on surface streets with no problem at all.
unboundmo
Report this Post03-09-2015 03:55 PM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would powder coat them.. When cured they be okay until 800 degrees. Mine are powder coated red. My ride is maroon
[This message has been edited by unboundmo (edited 03-11-2015).]
E.Furgal
Total ratings: 278
Report this Post03-10-2015 04:28 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
something is very very wrong if a hydra boost is getting so hot that the master is getting that hot.. find another dealer, cause that one eck..
rogergarrison
Total ratings: 551
Report this Post03-10-2015 06:38 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
3 truck dealers and 2 RV dealers found nothing at all wrong with the brakes. The pads are like new. It has 14,000 miles.
Fiero84Freak
Report this Post03-12-2015 09:45 AM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is my stock brakes painted on an '86 GT. Sorry I don't have the best shot of them. The wheels are older 15" ASA JS7s running the stock Fiero GT tire sizes.
What I did instead of painting the entire caliper was just paint the "face" of it. Since unless you're REALLY up on it you can't really see much behind the caliper anyway, it made sense just to mask as deep as I needed to go, then spray away. I cleaned the outer face of the caliper really well with a scrub brush and then put five coats of DupliColor Red Caliper Paint.
The color held up fine.
