  removing tail light harness
removing tail light harness by zipper9
Started on: 10-29-2014 08:52 PM
Replies: 1 (106 views)
Last post by: Indyellowgt on 10-30-2014 06:08 AM
zipper9
Report this Post10-29-2014 08:52 PM Click Here to See the Profile for zipper9Send a Private Message to zipper9Edit/Delete MessageReply w/QuoteDirect Link to This Post
can the tail light harness be removed without removing the fast back clip?
Indyellowgt
Total ratings: 70
Report this Post10-30-2014 06:08 AM Click Here to See the Profile for IndyellowgtSend a Private Message to IndyellowgtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey there.
I believe so.... if you take the inner quarter window panel out,then remove the foam tape that goes over the harness,you should have just enough room to tuck it thru under the body. You'll have to take out the inner wheel well liner as well.
Good luck.
Mark
