  need 91 sunbird gauge cluster diagram and yes this is fiero related putting it in
need 91 sunbird gauge cluster diagram and yes this is fiero related putting it in by mmeyer86gt/gtp
Started on: 10-28-2014 12:37 AM
Replies: 6 (354 views)
Last post by: Doober on 10-31-2014 01:01 AM
mmeyer86gt/gtp
Total ratings: 73
Report this Post10-28-2014 12:37 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
need 91 sunbird gauge cluster diagram and yes this is fiero related putting it in. I bought a 89 factory book and the wiring is different than in 91.
Doober
Report this Post10-29-2014 04:57 PM Click Here to See the Profile for DooberSend a Private Message to DooberEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are the colors different between vehicles?
mmeyer86gt/gtp
Total ratings: 73
Report this Post10-29-2014 09:27 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
no the wiring schematic
AL68
Report this Post10-30-2014 11:25 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
My Mitchell program will only save the schematics as an XPS file - emailed it to you, hope it will work.
AL
mmeyer86gt/gtp
Total ratings: 73
Report this Post10-31-2014 12:03 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
i looked it over but very confusing,,,, no ports for the turbo gauge setup wrong cluster thanks.
AL68
Report this Post10-31-2014 12:46 AM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
sure it's not a 1990 - I can't find any info on a 1991 having a turbo but the 1990 shows a turbo cluster - just sent it to you.
pin # 17 LT Green goes to the map sensor green wire, I used an 87 Sunbird tach/boost gauge in my 86 GT cluster.
[This message has been edited by AL68 (edited 10-31-2014).]
Doober
Report this Post10-31-2014 01:01 AM Click Here to See the Profile for DooberSend a Private Message to DooberEdit/Delete MessageReply w/QuoteDirect Link to This Post
My point is the wire color scheme on many GM vehicles from at least the '80s through the '90s is the same for many/most of the sending units/sensors, among other things... i.e. the coloring for the sending units and lighting in my '78 Malibu are the same as my '92 GMC pickup - tan is oil pressure sending unit/switch, pink/black is cluster power I believe, white is tach, light green (or maybe dark green?) is water temp, brown is charge light, etc.
