  What am I missing with this Bracket?
What am I missing with this Bracket? by DKcustoms
Started on: 08-20-2014 10:03 PM
Replies: 2 (182 views)
Last post by: DKcustoms on 08-21-2014 07:28 PM
DKcustoms
Report this Post08-20-2014 10:03 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm trying to reinstall my gas tank, fuel filter, and new stainless steel lines, but I think I misplaced something.
I know the lines coming from the tank are evap, return, and feed, starting from the drvier's side, but I am trying to mount the feed and return lines after the filter and I think I lost something.
I remember the bracket being attached to the hole near the cradle bolt.
and I think the bracket that was in that hole used these two pieces, but I think there is something else that is used to attach the lines to said bracket.
Does anyone have a picture of this bracket or area of the car?
Any ideas or tips?
Anything is appreciated, thanks
fierogt28
Report this Post08-21-2014 12:05 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
The "L" shaped bracket goes next to the cradle mount bolt. So you are correct.
They hold both fuel lines together.
The other bracket goes on the tank side of the fuel filter. The are two screws that go in
strait up on the chassis.
On both brackets, you have a "U" loop fastener that goes around the fuel tubes. The smaller
screw goes in the smaller hole on the bracket to secure them together.
Hope this helps.
DKcustoms
Report this Post08-21-2014 07:28 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes thanks.
I figured out what you mean by U clamps, although I would have called them something different
