  SCCA Solo National Tour in my 88 3800SC Coupe
SCCA Solo National Tour in my 88 3800SC Coupe by mattman134
Started on: 08-08-2014 08:04 PM
Replies: 2 (289 views)
Last post by: mattman134 on 08-09-2014 11:50 AM
mattman134
Report this Post08-08-2014 08:04 PM Click Here to See the Profile for mattman134Send a Private Message to mattman134Edit/Delete MessageReply w/QuoteDirect Link to This Post
I recently raced at the Wilmington Solo National Tour in my prepped 3800SC 88 Base Coupe. I am stuck in SSM due to the engine swap, and was on 225 Hankook Z214s all around. Finished with a 57.018 as my best time, which is good for the top 25% or so.
Car has poly bushings (of course), Koni reds and 400lb QA1 springs rear, Bilstein AKs and 700lb springs up front.
Alignment specs:
Front Camber: -2.3 degrees L, -2.1 degrees R
Front Caster: 5.7 degrees L, 5.4 degrees R
Front toe: -0.25 total
Rear Camber: -1.5 degrees L, -1.5 degrees R
Rear toe: 0.10 total
Car feels really neutral in the turns, with the ability to get the car to rotate at will with a blip of the brake. Mat it again and the rear hooks. I had to set my konis to full soft, which means I may be too stiff on the rear springs, or may need more camber in the rear. I can pretty much throw the car around and it is very composed.
I took several videos, these are my best run:
https://www.facebook.com/ph...63134&type=2&theater
A few pics:
The car fully prepped
Trackmaster Map of the course
[This message has been edited by mattman134 (edited 08-08-2014).]
Total ratings: 463
Report this Post08-09-2014 01:34 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good run.
Doesn't the empty drink bottle and other assorted items flying around on the floor in front of the passenger seat distract you? We're not allowed to have anything loose in our cars during a run... for good reason! On the rare occasion that some lost item sneaks out from under the passenger seat during a run, I don't like it at all.
mattman134
Report this Post08-09-2014 11:50 AM Click Here to See the Profile for mattman134Send a Private Message to mattman134Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yea I should have removed the stuff from the passenger floor, I didn't pay attention to the stuff flying around haha. I probably would have been yelled at by the safety steward if he saw it
