  SCCA Solo National Tour in my 88 3800SC Coupe
SCCA Solo National Tour in my 88 3800SC Coupe by mattman134
Started on: 08-08-2014 08:02 PM
Replies: 0 (284 views)
Last post by: mattman134 on 08-08-2014 08:02 PM
mattman134
Report this Post08-08-2014 08:02 PM Click Here to See the Profile for mattman134Send a Private Message to mattman134Edit/Delete MessageReply w/QuoteDirect Link to This Post
I recently raced at the Wilmington Solo National Tour in my prepped 3800SC 88 Base Coupe. I am stuck in SSM due to the engine swap, and was on 225 Hankook Z214s all around. Finished with a 57.018 as my best time, which is good for the top 25% or so.
Car has poly bushings (of course), Koni reds and 400lb QA1 springs rear, Bilstein AKs and 700lb springs up front.
Alignment specs:
Front Camber: -2.3 degrees L, -2.1 degrees R
Front Caster: 5.7 degrees L, 5.4 degrees R
Front toe: -0.25 total
Rear Camber: -1.5 degrees L, -1.5 degrees R
Rear toe: 0.10 total
Car feels really neutral in the turns, with the ability to get the car to rotate at will with a blip of the brake. Mat it again and the rear hooks. I had to set my konis to full soft, which means I may be too stiff on the rear springs, or may need more camber in the rear. I can pretty much throw the car around and it is very composed.
I took several videos, these are my best run:
<div id="fb-root"></div> <script>(function(d, s, id) { var js, fjs = d.getElementsByTagName(s)[0]; if (d.getElementById(id)) return; js = d.createElement(s); js.id = id; js.src = "//connect.facebook.net/en_US/all.js#xfbml=1"; fjs.parentNode.insertBefore(js, fjs); }(document, 'script', 'facebook-jssdk'));</script>
<div class="fb-post" data-href="https://www.facebook.com/photo.php?v=10153083724603135" data-width="466"><div class="fb-xfbml-parse-ignore"><a href="https://www.facebook.com/photo.php?v=10153083724603135">Post</a> by <a href="https://www.facebook.com/FyrHzrd">Matt Howard</a>.</div></div>
