  Any 3.4 DOHC owners chime in
Any 3.4 DOHC owners chime in by Rick 88
Started on: 08-02-2014 08:07 PM
Replies: 35 (1146 views)
Last post by: Rick 88 on 09-27-2014 01:25 PM
Rick 88
Report this Post08-02-2014 08:07 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am considering a 3.4 DOHC swap and would like input from anyone who has done the swap, drives this swap regularly, or offers parts or info on the swap. Tell me the good, bad, and ugly.
The plan is to purchase and install a basically stock DOHC with a Fiero Getrag on an 88 cradle. Anyone selling a complete low mileage take out, or if you have a crate motor collecting dust, PM me with pictures and a price. I know the 3800's are faster but I want the broad rpm range of this engine, and have heard they sound great. Any sound clips you can post would be appreciated too.
MstangsBware
Total ratings: 459
Report this Post08-02-2014 10:05 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
I loved the DOHC Formula I had and would have to say it was the most fun swapped Fiero I have driven and that's beating out modded 3800s. The DOHC on the 5 speed is the perfect engine setup for the Fiero when u want a car that handles and drives damn near perfect. I loved being able to bring the RPMs up to 7K and the exhaust not just got sweeter the higher the RPMs went. It is probably one of the few cars I sold that I actually hated see going but the herd had to be thinned and being an AC delete car it went. I DD for some time and to several events in Tx and OK with no issues at all. The buyer flew in an drove it 750 miles home to Las Cruces New Mexico with no issues and said he loves the car. The only down side to me is iit's size as any work done to it is gonna be a pain cause of the tight fit.
The swap is actually very easy and straight forward as not a lot of special order parts r used. The 88 front engine mount is moddemodded for the DOHC and then u pic what type mounts u wanna use. U use a 88 flywheel along with a Getrag clutch of ur choice. The wiring needs to be integrated but there are several on the board that can do that.
I have a aluminum flywheel with about 1500 miles on it that is for sale of u decide to do the swap. I pulled it off the 3.1 in the Formula I picked up when I swapped the clutch out...
I plan on doing a DOHC swap into my empty 88 GT in the future..
[This message has been edited by MstangsBware (edited 08-02-2014).]
Silicoan86
Report this Post08-04-2014 02:47 AM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 3.4 DOHC in my 86 and have daily driven it for the last 3 summers.
I agree with pretty much everything MstangsBware said. It's not the fastest swap out of the box, but IMO it's the most fun of the common swaps when mated to a manual trans. Winding this thing out to 7k is an absolute blast and the exhaust note while doing so is downright orgasmic.
IMO the biggest task to overcome is finding one in good shape these days. Solid used engines are getting scarce. Crate engines are still floating around, you just need to have the patience for one to pop up.
I would recommend starting with an OBD2 (96-97) engine if possible. The others are fine too (mine's OBD1) but there are benefits to running the later year engines such as the redesigned heads and intake as well as SFI and better tuning options.
I have sound clips but I'll need to find a way to post them. The clips sound good, but just don't quite portray it as well as hearing it in person.
Rick 88
Report this Post08-04-2014 09:32 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Mstangs,
Las Cruces is just up the road from me. Can you PM me contact info on the guy that purchased it. Maybe I can get him to be part of our Fiero group here in El Paso. Who here can build a harness for me?
Thanks,
Rick
Rick 88
Report this Post08-04-2014 09:38 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rick 88
Member since Aug 2001
Thanks for the info. I have found a 95 OBD1 SFI crate engine. Since this motor is SFI can it use an OBD 2 harness and ECM? Unless there are any 96-97's engines out there this one should work for me. My car is an 88 Mera 5-speed and I thought this engines sound would be perfect coming out the back of my car.
[This message has been edited by Rick 88 (edited 08-04-2014).]
qwikgta
Total ratings: 84
Report this Post08-04-2014 09:51 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a 96 3.4 DOHC motor in my 88. Loved it.
Go to Google and type this: site:fiero.nl 3.4 DOHC
it will return all the threads in Pennocks that have 3.4 DOHC in them. I tried to start each thread with 3.4 DOHC so it will help the search. You should find everything your looking for with that search
Rob
qwikgta
Total ratings: 84
Report this Post08-04-2014 09:52 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
qwikgta
Member since Jan 2001
if you want to see just my threads, type this in google: site:fiero.nl 3.4 DOHC, qwikgta
Rob
ltlfrari
Total ratings: 127
Report this Post08-05-2014 08:29 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
See all about my swap on my site http://www.ltlfrari.com/ click on DOHC Swap tab.
Sadly long since gone after a crash.
Dave
www.ltlfrari.com
bonaduce
Report this Post08-05-2014 01:18 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I followed little ferrari's build almost to the letter, and must say that it is spot on. Now if Darth and I can figure out why it is running pig rich, I may be able to chime in.
dan
Fieroking
Total ratings: 78
Report this Post08-06-2014 01:58 AM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 96 DOHC in my 85 Fiero. Love the 7k red line with the manual trans. Had the swap done for 5 years and only had one problem with it when tensioner broke on the highway. No damage to the engine ( supose to be a interference engine).
Joe Sokol
85 SE Daily driver with a 3.4 DOHC OBD II
88 Formula/GT 4.9 Allante Intake (My Baby)
www.fieroking.com
Rick 88
Report this Post08-06-2014 04:56 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Guys,
I am glad everyone that has one seems to like this motor. Does this motor sound fairly European? I am going to be putting it in a Mera. I'm hoping it has a bit of an Italian sound going thru the gears. Thanks for all the tips. Any one you recommend to do the harness. From all the research I have done, Sinister Performance is the place.
I also need tips on exhaust systems, A/C, Cruise, plumbing, etc. PM me or post away. I am reading everything I can find.
Thanks!!!
Silicoan86
Report this Post08-06-2014 07:11 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Taken with a smart phone, unfortunately the microphone really doesn't do it justice.
Specs
1992 3.4L DOHC
1996 intake swap
Internally balanced and bored .030" over
FFP underdrive pulley
Stock front and rear exhaust manifolds with 2.5" mandrel bent exhaust into a DynoMax muffler with Corvette C6 tips.
Disregard the slow shift, my Isuzu does not like going into second at anything higher than the original Duke's RPM range.
[This message has been edited by Silicoan86 (edited 08-06-2014).]
ltlfrari
Total ratings: 127
Report this Post08-07-2014 09:15 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's a a video of mine on my web site in videos section. Sounds more like a chevy to me LOL!
Dave
www.ltlfrari.com
Rick 88
Report this Post08-09-2014 06:01 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
How are you guys doing on gas mileage if you can keep you foot out of it?
Silicoan86
Report this Post08-10-2014 09:59 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I typically get about 23mpg around town and 30mpg freeway.
tesmith66
Total ratings: 135
Report this Post08-11-2014 06:33 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Which transmission are you running?
1986 SE Aero coupe.
Silicoan86
Report this Post08-11-2014 10:36 AM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Isuzu 5 speed.
Report this Post08-11-2014 02:22 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've ridden in a 3.4L TDC engine Fiero and these are my ,observations and opinions based upon research, discussions with owners
The engine seems to fit the Fiero engine compartment but looks quite massive in there. I do not know if it is possible to change plugs without dropping the cradle
The swap appears to be a bolt in with a stick (that also lends itself best to the power curve).
The engine is an early attempt by GM at making a DOHC engine based on the 60* V6 block design. The design is quite old, low mileage examples are difficult to find but crate engines pop up every now and then
There have been some oiling reliability issues and the timing belts must be changed at 60K miles.
The gas mileage and power down low is average but in the 4000-6500 RPM band it really talks off. Over 400HP is possible using boost. ex: Matt Hawkins
This has never been a very popular Fiero swap but there are a small amount of Fiero owners that love this engine.
zzzhuh
Report this Post08-11-2014 05:42 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Isuzu 5 speed.
I figured that transmission would blow up the second you give it any gas.
Silicoan86
Report this Post08-11-2014 06:10 PM Click Here to See the Profile for Silicoan86Send a Private Message to Silicoan86Edit/Delete MessageReply w/QuoteDirect Link to This Post
I recently acquired a Getrag to replace it, so I've been driving it pretty hard now that I've got a spare on hand. It seems to hold up pretty well actually. Like I mentioned, It's really hard to shift into second until the rpms fall back down to Iron Duke levels, and that may be helping the matter since I can't shift that hard into second gear which is known to be the Isuzu's weak point.
IMO the 3.4 dohc tends to be easy on transmissions due to its high rpm powerband, at least compared to engines like the 4.9 which has a full 270+ ft-lbs of torque from the moment you slam it into second gear and let out the clutch.
Rick 88
Report this Post08-21-2014 09:03 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
The crate engine I will be using is a 95 SFI version, I am going to be installing it with a Getrag.
I also have an NOS export Getrag with the 3.91 final drive. There have been posts on here about building a hybrid close ratio gearbox using the 1/2 gearset of the Fiero Getrag along with the remainder of the export gearing and 3.91 final drive. The export box uses a Quad 4 bellhousing which would need to be swaped. The export first to second gearset in it is supossed to be very short compared to the Fiero first and second since this trans was used in a GM minivan. With the additional DOHC power would buiding a gearbox like this be a benefit or not?
On the cruise control, it is better to use the Fiero system or the electronic cruise these motors came with? Also I am going to need recommendations on an exhaust system. I don't want to cut the trunk as I actually travel in my car on occasion. Since my car is over 25 years old it no longer has to have an emission test. Would the DOHC perform better without the convertor?
[This message has been edited by Rick 88 (edited 08-22-2014).]
Rick 88
Report this Post08-23-2014 07:52 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Guys,
Can you offer any info on building a harness. I have been told any 85-88 Manual Transmission V6 harness will be able to be tied in to the DOHC harness.
I want to build the swap on another cradle and be able to have it pretty close to complete before it is installed in the car.
Rick 88
Report this Post08-25-2014 08:46 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did any of you guys run you exhaust system without a convertor? If so did you notice any power improvement? In Texas you don't have to meet emissions once the car is 25 years old.
Steven Snyder
Total ratings: 106
Report this Post08-26-2014 12:38 PM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have over 60k miles on my 3.4 DOHC swap. I first swapped it in 2005. I have run dozens of track days in the California heat. It's a great engine for the track due to the broad powerband and high rev limit. When I first did the swap I had an Isuzu 5 speed and I sheared all the teeth off 2nd gear.. so I don't recommend that transmission for anything. A Getrag with the long 5th will get ~27 mpg on the highway on an otherwise stock Fiero.
Spark plugs are easy if you crack the rear wire holders in half so you can remove them without hitting the rear firewall shelf. You will need a magnetic spark plug holder and some short extensions to feed in one by one. The rear spark plugs are very straightforward.
Don't buy a used motor. Get a crate motor or plan on doing a rebuild (budget ~$3500 -- so get the crate motor instead!). When these engines aren't taken care of the intermediate shaft bearing can fail and send debris through the rest of the oiling system. Sound familiar? Google Porsche IMS bearing... The fix is to disassemble the motor and replace the front intermediate shaft bearing with the longest one that will fit. I think it's an SBC camshaft bearing or something. If it's a new motor you do not have to worry about this.
It takes about 10 minutes to remove and replace all 6 spark plugs. Actually, all of the maintenance is very easy except the timing belt.
The timing belts are annoying. I'm not aware of any oiling reliability issues. I've been running my car hard on the track and the only issue I've seen is high oil temps, but that's a problem with everyone's car out here in the 105*F heat without additional coolers.
Rick 88
Report this Post08-26-2014 09:18 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Steve,
I have purchased a 95 SFI crate motor. I plan to keep the install as close to stock as possible for increased reliability. I hope to be able to drive it regularly and take some trips in the car. I plan to keep A/C and cruise. My car is a Mera, and I thought this engine would make the right exhaust sound for the Mera bodywork. Any tips on what kind of muffler to run? Or should I just keep the stock V6 Fiero muffler. I have always liked the sound it produced.
Another question. What did you guys do concerning the oil fill cap being on the firewall side of the engine. Can another cam cover be installed with a cap on the trunk side?
[This message has been edited by Rick 88 (edited 08-26-2014).]
Steven Snyder
Total ratings: 106
Report this Post08-29-2014 02:18 AM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the Fiero muffler would be too restrictive. You need a 2.5" exhaust system.
You can't put a trunk side oil fill on with the stock intake. If you make a different upper intake manifold you could accommodate an oil fill.
[This message has been edited by Steven Snyder (edited 08-29-2014).]
qwikgta
Total ratings: 84
Report this Post08-30-2014 03:22 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
a lot of the stuff you need are in the old posts, I know I asked a lot of questions and got some great advice. Use the google search method I posted above to find things here fast.
My setup was: 88 Coupe. 96 Motor, stock 88 Isuzu trans. (wish I had a Getrag, but i had no issues with the isuzu)
My 96 was wired up as a 91 (OBD 1) system. I used the ECM and harness off an 91 Cutlass that was originally a 5 speed car. I wanted to start with a 5 speed trans and not have to modify an Auto harness. I had to replace a few sensors because the 96 - 91 had some differences. Nothing to bad. I built my harness on my kitchen table using the pin outs found online. A few years ago, there was a DOHC website that has a lot of great info on it. One of the pages had a pin out diagram that was 97% spot on. In the end, I purchased a 91 Cutlass Service Manual off the web and used the pin out pages to trace every wire (54 of them) I also removed the stock 91 relay center. It cleaned up the harness and it looked great. For exhaust I ran headers, they were custom made so I can't offer any advice, however, I also used the cat-back system from WCF, I bought the 2.5" set up and Spintek muffler. I sounded great and I had no option but to use a "high flow" Cat. The new high-flow cats offer almost no back pressure issues so I would not worry that much about it.
about half way down this thread you will see some pics of my engine after I pulled it out to install an LS3. https://www.fiero.nl/forum/A...130314-2-113690.html
Rob
hookdonspeed
Total ratings: 131
Report this Post08-31-2014 07:27 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lol, any Chance you still have that y pipe and wana sell it? :P
Rick 88
Report this Post09-01-2014 05:58 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would be interested in any 3.4 DOHC swap pull out parts as well. PM me with any parts you have avaialble I might need.
Rick 88
Report this Post09-13-2014 04:00 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can you guys post some pics of your exhaust systems, and let me know why you made them that way. My engine is a 95 SFI. I understand it is better if you change on of the exahust manifolds for one from the other side. Which one do I need? If any of you have a built system for sale, send me a PM.
engine man
Report this Post09-13-2014 08:58 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a 84 with 88 cradle and 3.4 dohc install was simple and was a fun car to drive with 4:10 4 speed for exhaust pipe size go to this site
http://www.exhaustvideos.co...-size-pipe-diameter/
[This message has been edited by engine man (edited 09-14-2014).]
Fierobsessed
Total ratings: 147
Report this Post09-14-2014 12:23 AM Click Here to See the Profile for FierobsessedSend a Private Message to FierobsessedEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a PM. I've got swap parts.
Rick 88
Report this Post09-16-2014 10:55 AM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM sent.
I know I am late to the party for this swap. For you guys that still have them how have they held up? For those that pulled them, whey did you do it? I drove a new Grand Prix 5-speed with a DOHC back in the day, and the engine pulled very well and was extremely smooth.
On the rear suspension did anyone install stiffer springs due to the added weight on the engine? Is the additional weight that noticeable if you are just using the car as a driver?
Anyone else have swap parts they want to sell?
[This message has been edited by Rick 88 (edited 09-17-2014).]
Rick 88
Report this Post09-20-2014 07:04 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
PM replied.
Racer_JT
Report this Post09-23-2014 11:48 PM Click Here to See the Profile for Racer_JTSend a Private Message to Racer_JTEdit/Delete MessageReply w/QuoteDirect Link to This Post
and it is in this
[This message has been edited by Racer_JT (edited 09-23-2014).]
Rick 88
Report this Post09-27-2014 01:25 PM Click Here to See the Profile for Rick 88Send a Private Message to Rick 88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cool! Tell me more. Any track videos?
