Part Numbers for rear firewall wiring bulkhead pass through by Will
Started on : 01-18-2014 06:57 PM
Replies : 10 (519 views)
Last post by : Will on 02-09-2014 12:14 PM
Jan 18th, 2014
Will Member Posts: 14303 From: Where you least expect me Registered: Jun 2000
Does anyone have the part numbers for the bulkhead pass through where the engine wiring harness goes through the firewall to the computer?
06:57 PM
Jan 21st, 2014
DKcustoms Member Posts: 1071 From: Central NY Registered: Oct 2013
Is this the part you are talking about? If so, there are no numbers or letters on it at all except for "PED 2" near the large opening on the black half.
I am just reusing mine from my original harness in my new one.
Hope this helps.
02:15 PM
Feb 7th, 2014
That's it. I've reused them before. I've also come across wider ones (e.g. from a Pontiac 6000), but I've never seen part numbers for them. The ones in my car are a bit broken right now and not secure in the hole in the firewall.
10:01 PM
Bloozberry Member Posts: 7760 From: Registered: Jan 2009
I checked the 22P but the bulkhead connector is an integral part of the wire harness.
10:08 PM
As delivered from GM, yes. However, it has to have a Delco or Delphi part number somewhere...
11:16 PM
olejoedad Member Posts: 20026 From: Back home again in Indiana Registered: May 2004
The only markings I can see on the set I just examined are
P E D 7 on the larger part.
P E D 4 on the smaller part.
I see no other markings.
[This message has been edited by olejoedad (edited 02-07-2014).]
11:58 PM
Feb 8th, 2014
fierogtlt1 Member Posts: 1006 From: Orlando,Florida U.S.A Registered: Jul 2012
Bulkhead small pins Male Mouser Part #: 829-12077628 Manufacturer Part #: 12077628 Bulkhead small pins Female Mouser Part #: 829-12084200 Manufacturer Part #: 12084200 Bulkhead mid pins Male Mouser Part #: 829-12129497 Manufacturer Part #: 12129497 Bulkhead mid pins Female Mouser Part #: 829-12129493 Manufacturer Part #: 12129493 Bulkhead Large pins Male Mouser Part #: 829-12064736 Manufacturer Part #: 12064736 Bulkhead Large pins Female Mouser Part #: 829-12052456 Manufacturer Part #: 12052456 C203 Female Pins Mouser Part #: 829-12162595 Manufacturer Part #: 12162595 GM Weatherpack Male pins (Fuel Pump pigtail, MAP,etc) Mouser Part #: 829-12146501 Manufacturer Part #: 12146501 GM Weatherpack Female pins Mouser Part #: 829-12089188 Manufacturer Part #: 12089188 Most of the GM 3800 sensor pins (Cam/crank, ECT,etc) Mouser Part #: 829-12124075 Manufacturer Part #: 12124075 Injector Pins Mouser Part #: 829-12103360 Manufacturer Part #: 12103360
12:05 AM
quote Originally posted by fierogtlt1: Bulkhead small pins Male Mouser Part #: 829-12077628 Manufacturer Part #: 12077628 Bulkhead small pins Female Mouser Part #: 829-12084200 Manufacturer Part #: 12084200 Bulkhead mid pins Male Mouser Part #: 829-12129497 Manufacturer Part #: 12129497 Bulkhead mid pins Female Mouser Part #: 829-12129493 Manufacturer Part #: 12129493 Bulkhead Large pins Male Mouser Part #: 829-12064736 Manufacturer Part #: 12064736 Bulkhead Large pins Female Mouser Part #: 829-12052456 Manufacturer Part #: 12052456 C203 Female Pins Mouser Part #: 829-12162595 Manufacturer Part #: 12162595 GM Weatherpack Male pins (Fuel Pump pigtail, MAP,etc) Mouser Part #: 829-12146501 Manufacturer Part #: 12146501 GM Weatherpack Female pins Mouser Part #: 829-12089188 Manufacturer Part #: 12089188 Most of the GM 3800 sensor pins (Cam/crank, ECT,etc) Mouser Part #: 829-12124075 Manufacturer Part #: 12124075 Injector Pins Mouser Part #: 829-12103360 Manufacturer Part #: 12103360
Thanks. I appreciate the effort, but those aren't what I'm looking for.
10:53 AM
jsmorter Member Posts: 124 From: creston ohio usa Registered: Jun 2013
Where are you located?
10:57 AM
Dave E Bouy Member Posts: 1465 From: Kettle Point Ontario Canada Registered: Sep 2004
quote Originally posted by jsmorter: Where are you located?
Where you least expect him of course-
11:00 PM
Feb 9th, 2014
Northern Virginia. Why?
12:14 PM
