  How to Store Fiero Outside For Winter
How to Store Fiero Outside For Winter by jon2009
Started on: 12-27-2013 10:31 PM
Replies: 12 (401 views)
Last post by: 2.5 on 12-30-2013 05:01 PM
jon2009
Report this Post12-27-2013 10:31 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
i wanted some ideas of how i should store my 88 Fiero Gt outside for winter, because of the lack of storage room.
In order to minimize rust forming on the body of the car, and also the under body.
let me know
thanks
Old Lar
Total ratings: 214
Report this Post12-28-2013 07:54 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used to have a breathable car cover over my Fiero. I'd suggest keeping off bare ground. When I lived in the snow belt, my 87 GT went under wraps by November and uncovered in mid March. The only issues I had was when the winter winds hit 50 mpg and blow the cover off, however it had a cable strapping it underneath, so the cover didn't blow away.
The downside can be some paint abrasion where the cover flaps against the paint.
RCR
Total ratings: 102
Report this Post12-28-2013 08:46 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
I've only done it once, but it seemed to work well.
First I filled the car with dryer sheets. Supposed to help keep varmits out.
Then I drove the car up on a large tarp, and wrapped it around the car. Then wrapped another over the top.
I suppose it would be better to get the car off the ground, too.
Good luck.
Bob
Sile
Report this Post12-28-2013 12:09 PM Click Here to See the Profile for SileSend a Private Message to SileEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just drive mine :P
cam-a-lot
Total ratings: 97
Report this Post12-28-2013 12:27 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oil spray all exposed metal surfaces underneath.
tesmith66
Total ratings: 135
Report this Post12-28-2013 07:17 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Don't worry about rust on the body
Vernon8360
Report this Post12-28-2013 08:52 PM Click Here to See the Profile for Vernon8360Send a Private Message to Vernon8360Edit/Delete MessageReply w/QuoteDirect Link to This Post
Where is Brampton?
RCR
Total ratings: 102
Report this Post12-29-2013 09:03 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Vernon8360:
Where is Brampton?
Ontario, Canada... But I suppose there is more than one...
Bob
Report this Post12-30-2013 12:01 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've stored some cars outside, not a Fiero yet thankfully.
As for rust dont store it on concrete or pavement. Dirt or even grass is fine. The paved surfaces sweat moisture up onto the car. One could put barriers under the car, but I have not done that outside, only indoor cold storage, I used layers of cardboard. Outside maybe a rubber mat would work, but rodents might like to chew it.
You could block it up higher off the ground as well.
A major concern could be rodents. Various tricks exist to keep them out of the car. make sure the car has nothing that they like, no old french fries under the seat for example.
An easy one is just add a ton of dryer sheets all over inside cabin, trunk, underhood, in exhaust exits, around engine bay, they seem to not like the smell of them.
Put Stabil in the gas and fill the tank with mid grade octane no ethanol if you can, (it takes longer to spoil).
Disconnect the battery (I bring mine inside to store warm).
A car cover that fits well and is made for the elements, but Id say not a plastic tarp, they trap moisture which will get excessive when temps rise after being cold, and if a cover moves in the wind it can damage paint by abrasion.
The oil spray is a good idea. On my daily driver Saturn, and my pickup which is always outside I spray most of the underside with CorrosionX.
http://www.corrosionx.com/corrosionx.html
We are assuming you are in Canada so it will be cold.
[This message has been edited by 2.5 (edited 12-30-2013).]
Report this Post12-30-2013 01:43 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tire can "rot" fast when parked on dirt/grass.
The tread can get cracks when contact on dirt/grass.
Crack can expose the belts, then everything can attack the belts if driving after.
Look at tread's slots for cracking.
Report this Post12-30-2013 02:31 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting, amend my input to read: put peices of something under the tires, wood, plastic, etc.
rogergarrison
Total ratings: 551
Report this Post12-30-2013 04:52 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually the opposite is true. You WANT to store it over concrete or pavement. Parking over gravel, dirt or grass MAKES it rust because they all remain damp or wet for a long time because its shaded under the car. Def good idea to have the tires off the ground. Block it up as far out on the A frames as you can get so the suspension stays loaded. Dont leave them hanging. I had 2 broke down muscle cars parked out back for a few years that were in pretty much the same condition. One was on pavement and other was on grass in front of it. The one on the grass had all the floors, rockers and fender bottoms rotted out while the other was fine. I ended up junking the one on the grass.
Report this Post12-30-2013 05:01 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Much of this depends on the ground, sandy, black dirt, clay. Also depends on the climate, wind, how much snow, etc.
But it could be because I'm thinking what we are talking about is winter storage only, which for me includes parking before roads get salted and parked until the snow melts, then the car gets driven again. The ground is frozen most of this time. Its the times when things are warming up that concrete sweats.
